Zarafa Installation und Management Console Server
die Installation von Zarafa (7.1.13-51032) bricht bei ca. 90% ab und schießt den Management Server ab.
UCS ist die aktuelle Version und ansonsten ist noch Owncloud und Doku-Wiki installiert.
Ein “invoke-rc.d univention-management-console-server restart” oder rebooten bringt nichts.
Fehlermeldung
Interner Server Fehler: Der Dienst ist momentan nicht erreichbar
The Univention Management Console Server is currently not running.
If you have root permissions on the system you can restart it by executing the following command:
* invoke-rc.d univention-management-console-server restart
The following logfile may contain information why the server is not running:
* /var/log/univention/management-console-server.log
Otherwise please contact an administrator or try again later.[/code]
Letzte Log Einträge in dpkg.log
[code]
2015-09-25 12:17:33 configure zarafa-gateway:amd64 7.1.13-51032 <keine>
2015-09-25 12:17:33 status unpacked zarafa-gateway:amd64 7.1.13-51032
2015-09-25 12:17:33 status half-configured zarafa-gateway:amd64 7.1.13-51032
[/code]
[code]25.09.15 09:37:05.987  MAIN        ( PROCESS ) : running: ['/usr/sbin/univention-management-console-module', '-m', 'appcenter', '-s', '/var/run/univention-management-console/26448-1443166625987.socket', '-d', '2', '-l', 'de_DE.UTF-8']
25.09.15 09:37:15.532  MAIN        ( PROCESS ) : running: ['/usr/sbin/univention-management-console-module', '-m', 'updater', '-s', '/var/run/univention-management-console/26448-1443166635532.socket', '-d', '2', '-l', 'de_DE.UTF-8']
25.09.15 09:42:03.288  MAIN        ( PROCESS ) : running: ['/usr/sbin/univention-management-console-module', '-m', 'setup', '-s', '/var/run/univention-management-console/26448-1443166923288.socket', '-d', '2', '-l', 'de_DE.UTF-8']
25.09.15 09:42:56.794  MAIN        ( PROCESS ) : running: ['/usr/sbin/univention-management-console-module', '-m', 'services', '-s', '/var/run/univention-management-console/26448-1443166976794.socket', '-d', '2', '-l', 'de_DE.UTF-8']
25.09.15 09:44:11.104  MAIN        ( PROCESS ) : running: ['/usr/sbin/univention-management-console-module', '-m', 'diagnostic', '-s', '/var/run/univention-management-console/26448-1443167051103.socket', '-d', '2', '-l', 'de_DE.UTF-8']
25.09.15 09:44:24.806  MAIN        ( PROCESS ) : running: ['/usr/sbin/univention-management-console-module', '-m', 'top', '-s', '/var/run/univention-management-console/26448-1443167064806.socket', '-d', '2', '-l', 'de_DE.UTF-8']
25.09.15 09:44:31.381  MAIN        ( WARN    ) : Socket died (module=ucr)
25.09.15 09:44:31.381  MAIN        ( WARN    ) : Module process ucr died (pid: 28450, exit status: -1, signal: -1, status: -1)
25.09.15 09:44:31.381  MAIN        ( WARN    ) : Cleaning up requests
25.09.15 09:44:31.381  MAIN        ( WARN    ) : Remove inactivity timer
25.09.15 09:44:31.381  MAIN        ( PROCESS ) : ModuleProcess: child died
25.09.15 09:45:33.418  MAIN        ( PROCESS ) : running: ['/usr/sbin/univention-management-console-module', '-m', 'ucr', '-s', '/var/run/univention-management-console/26448-1443167133417.socket', '-d', '2', '-l', 'de_DE.UTF-8']
25.09.15 09:45:34.978  MAIN        ( WARN    ) : Socket died (module=join)
25.09.15 09:45:34.978  MAIN        ( WARN    ) : Module process join died (pid: 28574, exit status: -1, signal: -1, status: -1)
25.09.15 09:45:34.978  MAIN        ( WARN    ) : Cleaning up requests
25.09.15 09:45:34.978  MAIN        ( WARN    ) : Remove inactivity timer
25.09.15 09:45:34.978  MAIN        ( PROCESS ) : ModuleProcess: child died
25.09.15 09:45:35.075  MAIN        ( WARN    ) : Socket died (module=udm)
25.09.15 09:45:35.075  MAIN        ( WARN    ) : Module process udm died (pid: 28362, exit status: -1, signal: -1, status: -1)
25.09.15 09:45:35.075  MAIN        ( WARN    ) : Cleaning up requests
25.09.15 09:45:35.075  MAIN        ( WARN    ) : Remove inactivity timer
25.09.15 09:45:35.075  MAIN        ( PROCESS ) : ModuleProcess: child died
25.09.15 09:45:35.189  MAIN        ( WARN    ) : Socket died (module=updater)
25.09.15 09:45:35.189  MAIN        ( WARN    ) : Module process updater died (pid: 28566, exit status: -1, signal: -1, status: -1)
25.09.15 09:45:35.189  MAIN        ( WARN    ) : Cleaning up requests
25.09.15 09:45:35.189  MAIN        ( PROCESS ) : ModuleProcess: child died
25.09.15 09:47:05.554  MAIN        ( WARN    ) : Socket died (module=appcenter)
25.09.15 09:47:05.554  MAIN        ( WARN    ) : Module process appcenter died (pid: 28573, exit status: -1, signal: -1, status: -1)
25.09.15 09:47:05.554  MAIN        ( WARN    ) : Cleaning up requests
25.09.15 09:47:05.554  MAIN        ( PROCESS ) : ModuleProcess: child died
25.09.15 09:47:06.216  MAIN        ( WARN    ) : Socket died (module=lib)
25.09.15 09:47:06.216  MAIN        ( WARN    ) : Module process lib died (pid: 28885, exit status: -1, signal: -1, status: -1)
25.09.15 09:47:06.216  MAIN        ( WARN    ) : Cleaning up requests
25.09.15 09:47:06.216  MAIN        ( WARN    ) : Remove inactivity timer
25.09.15 09:47:06.216  MAIN        ( PROCESS ) : ModuleProcess: child died
25.09.15 09:47:10.437  SSL         ( WARN    ) : SSL error in _receive: (-1, 'Unexpected EOF'). Probably the socket was closed by the client.
25.09.15 09:47:10.437  MAIN        ( PROCESS ) : Processor: dying
25.09.15 09:47:16.803  MAIN        ( WARN    ) : Socket died (module=updater)
25.09.15 09:47:16.803  MAIN        ( WARN    ) : Module process updater died (pid: 28901, exit status: -1, signal: -1, status: -1)
25.09.15 09:47:16.803  MAIN        ( WARN    ) : Cleaning up requests
25.09.15 09:47:16.803  MAIN        ( PROCESS ) : ModuleProcess: child died
25.09.15 09:47:46.072  DEBUG_INIT
25.09.15 09:47:46.073  MAIN        ( WARN    ) : Shutting down all open connections
25.09.15 12:08:58.044  DEBUG_INIT
25.09.15 12:08:58.272  MAIN        ( PROCESS ) : Server started
25.09.15 12:09:07.764  SSL         ( WARN    ) : SSL error in _receive: [('SSL routines', 'SSL23_READ', 'ssl handshake failure')]. Probably the socket was closed by the client.
25.09.15 12:09:29.166  ACL         ( PROCESS ) : Allowed UMC operations:
25.09.15 12:09:29.166  ACL         ( PROCESS ) :  User  | Host                 | Flavor          | Command              | Options
25.09.15 12:09:29.166  ACL         ( PROCESS ) : ******************************************************************************
25.09.15 12:09:29.166  ACL         ( PROCESS ) :  False | dc                   | *               | appcenter/*          | {}
25.09.15 12:09:29.166  ACL         ( PROCESS ) :  False | dc                   | *               | apps/*               | {}
25.09.15 12:09:29.166  ACL         ( PROCESS ) :  False | dc                   | *               | diagnostic/*         | {}
25.09.15 12:09:29.166  ACL         ( PROCESS ) :  False | dc                   | *               | ip/change            | {}
25.09.15 12:09:29.166  ACL         ( PROCESS ) :  False | dc                   | *               | join/*               | {}
25.09.15 12:09:29.166  ACL         ( PROCESS ) :  False | dc                   | *               | lib/*                | {}
25.09.15 12:09:29.166  ACL         ( PROCESS ) :  False | dc                   | *               | lib/server/*         | {}
25.09.15 12:09:29.166  ACL         ( PROCESS ) :  False | dc                   | *               | lib/server/reboot    | {}
25.09.15 12:09:29.166  ACL         ( PROCESS ) :  False | dc                   | *               | lib/server/shutdown  | {}
25.09.15 12:09:29.166  ACL         ( PROCESS ) :  False | dc                   | *               | lib/sso/*            | {}
25.09.15 12:09:29.166  ACL         ( PROCESS ) :  False | dc                   | *               | mrtg/*               | {}
25.09.15 12:09:29.166  ACL         ( PROCESS ) :  False | dc                   | *               | passwordchange/*     | {}
25.09.15 12:09:29.166  ACL         ( PROCESS ) :  False | dc                   | *               | pkgdb/*              | {}
25.09.15 12:09:29.166  ACL         ( PROCESS ) :  False | dc                   | *               | printers/*           | {}
25.09.15 12:09:29.166  ACL         ( PROCESS ) :  False | dc                   | *               | quota/*              | {}
25.09.15 12:09:29.166  ACL         ( PROCESS ) :  False | dc                   | *               | reboot/*             | {}
25.09.15 12:09:29.166  ACL         ( PROCESS ) :  False | dc                   | *               | services/*           | {}
25.09.15 12:09:29.166  ACL         ( PROCESS ) :  False | dc                   | *               | setup/*              | {}
25.09.15 12:09:29.166  ACL         ( PROCESS ) :  False | dc                   | *               | sysinfo/*            | {}
25.09.15 12:09:29.166  ACL         ( PROCESS ) :  False | dc                   | *               | top/*                | {}
25.09.15 12:09:29.166  ACL         ( PROCESS ) :  False | dc                   | *               | ucr/*                | {}
25.09.15 12:09:29.166  ACL         ( PROCESS ) :  False | dc                   | *               | udm/*                | {}
25.09.15 12:09:29.166  ACL         ( PROCESS ) :  False | dc                   | *               | udm/request_new_license | {}
25.09.15 12:09:29.166  ACL         ( PROCESS ) :  False | dc                   | *               | updater/*            | {}
25.09.15 12:09:29.305  MAIN        ( PROCESS ) : running: ['/usr/sbin/univention-management-console-module', '-m', 'appcenter', '-s', '/var/run/univention-management-console/6209-1443175769305.socket', '-d', '2', '-l', 'de_DE.UTF-8']
25.09.15 12:17:33.406  MAIN        ( WARN    ) : Shutting down all open connections
root@dc:~#
root@dc:~# apt-get install -f E: Der dpkg-Prozess wurde unterbrochen; Sie müssen manuell »dpkg --configure -a« ausführen, um das Problem zu beheben. root@dc:~# dpkg --configure -a zarafa-search (7.1.13-51032) wird eingerichtet ... [ ok ] Starting Zarafa search: zarafa-search. Trigger für python-support werden verarbeitet ... zarafa-gateway (7.1.13-51032) wird eingerichtet ... [....] Starting Zarafa gateway: zarafa-gatewayBeendet root@dc:~#
VG
Ich habe ähnlich Probleme mal gesehen, als ein Port, welcher von Zarafa benötigt wird, bereits belegt war. Ich meine es war seinerzeit Port 8080.
Laufen andere Dienste auf dem System?
