Zammad - Trigger not working
i got a problem with the trigger in zammad.
I want to configure a trigger, which sends a mail to the customer on ticket change.
The mail-config is working so far for example when a new ticket is created, a mail is send to the agents.
I tried several serverrestarts, new tickets, trigger configs and starting the trigger-scheduler, like described here.
Nothing is working.
Anyone with the same problem, or maybe a solution?
This triggerconfig should work as far as i can assess (it’s set to active, not shown in screenshot):
Bildschirmfoto_2019-11-12_21-09-26
Thanks for help.
I forgot to mention the versions:
UCS 4.4-2 errata301
Zammad 3.0.0-9
Hello @onomant ,
thank you for your question regarding Zammad. Please open a topic in the Zammad Forum , where you can reach the app provider. Thank you very much.
Best regards,
Nico
Ok, done.
If there will be a solution, i will refer here.
Greets
I forgot/didn’t know a seperate mail account set up to the destination-usergroup was needed.
Problem solved here.
Greetins
