Zammad smtp connection refused
Hi there,
in our admin-team, we’d like to switch from OTRS to zammad. The migration worked so far. But zammad cannot connect to the mailserver (running on the ucs docker host, where the zammad app is installed).
grafik
It seems that it could connect properly via IMAP, but not via submission (587) Am I missing something in the configuration?
I guess it is not recommended to edit the docker-files of the zammad app, right?
Cheers
Sebastian
Hello @audiolinux,
can you please open a topic at the Zammad forum ? There you can reach the app vendor. A link from this thread to that posting would be wonderful. Thank you very much.
Best regards,
Nico
Hey @gulden,
it was a wrong password in the env file. Changing that file, fixed the issue for us.
Cheers
Sebastian
Mastodon
