Zammad hat nicht installiert und lässt sich nicht entfernen
Hi, Zammad Docker Dienste starten, Site geht nicht.
univention-app-remove gibt folgendes endlos aus
# Start of Zammad-updatescript-magic #
Setting Status setting to empty...
Setting zammad/setting-feedback
Module: kopano-cfg
Ensuring that the provided settings are valid ...
Hostname has been set to pandora.sysops.de
Emptying setting as it's not needed (we don't want to case confusion)
Setting zammad/certificate
Module: kopano-cfg
# Working on apache configurations ... #
Adding port 10412 to Firewall (allowing that port) ...
Setting security/packetfilter/package/zammad/tcp/10412/all
Setting security/packetfilter/package/zammad/tcp/10412/all/en
File: /etc/security/packetfilter.d/10_univention-firewall_start.sh
Module: kopano-cfg
File: /etc/security/packetfilter.d/80_univention-firewall_policy.sh
W: The config registry variable 'security/packetfilter/package/zammad/tcp/8443/all' does not exist
Restarting Firewall ....
Removing old redirect-configuration ...
Work-around 'Open'-Button (building redirect from /zammad to vHost) ...
Removing old zammad.conf ...
Creating my zammad.conf (sites-available) vHost-config ...
Reloading apache ...
Site zammad already enabled
reinitialize bring auch nichts.
wie geh ich da am besten vor?
also das hängt immer noch beim remove
# ... Checking Zammad-State: 000                  #
bei upgrade kommt das
Starting zammad-backup        ...
 tarting zammad-nginx         ...  failed
4.3/zammad=3.1.0-7: Not running, cannot check further
unsupported operand type(s) for +: 'NoneType' and 'str'
  File "/usr/lib/python2.7/dist-packages/univention/appcenter/actions/__init__.py", line 226, in call_with_namespace
    result = self.main(namespace)
  File "/usr/lib/python2.7/dist-packages/univention/appcenter/actions/upgrade.py", line 81, in main
    return self.do_it(args)
  File "/usr/lib/python2.7/dist-packages/univention/appcenter/actions/install_base.py", line 119, in do_it
    self._do_it(app, args)
  File "/usr/lib/python2.7/dist-packages/univention/appcenter/actions/docker_upgrade.py", line 126, in _do_it
    self._upgrade_image(app, args)
  File "/usr/lib/python2.7/dist-packages/univention/appcenter/actions/docker_upgrade.py", line 171, in _upgrade_image
    old_docker.cp_from_container('/etc/machine.secret', app.secret_on_host)
  File "/usr/lib/python2.7/dist-packages/univention/appcenter/docker.py", line 399, in cp_from_container
    return docker_cp(self.container + ':' + src, dest, logger=logger, **kwargs)
TypeError: unsupported operand type(s) for +: 'NoneType' and 'str'
  File "/usr/bin/univention-app", line 91, in <module>
    main()
  File "/usr/bin/univention-app", line 78, in main
    ret = args.func(args)
hab jetzt während dem endloswarten alle zammad prozesse mit kill beendet.
danach hat er es entfernt
neuinstallation scheint zu passen
