I have just installed UCS with a basic mail server role , using zafara.
Webmail works perfect, I can send and receive mail for my registered domain.
Mail push work perfect from i-pad
Domain functionality works fine, I can join pcs to the domain and loging using a domain user.
howerver, I cannot connect using Outlook either internally or externally, I get either a server not online or a certificate error Using the self signed certificate at the moment, but i also have a purchased certificate wich is not installed on that machine right now)
the zafara-licensed (might be wrong packag name) is installed and service is running, il believe i need that to connect up to 3 accounts…
when I do a Telnet 25 both internally and externally i get proper responses,
so i’m a bit puzzeled as to what is mising (i suspect dns or certificate issue, but i can’t pinpoint it), this is the last bit i need to ditch my Windows based mail server…
as a precision, linux is pretty new to me and i’m not a mail pro, just basic konwledge
any suggestion would be greatly apreciated
Thank you,
JP
