Z-Push WITHOUT Kopano?
Has anyone successfully used Z-Push with the standard Univention mail server setup (Postfix/Dovecot)? According to the Z-Push documentation, it can work with any IMAP server or directly with maildir folders (and Dovecot can save its data in maildir folders). I don’t want to use Kopano. I’d like to use the standard server with a simple web frontend like Roundcube. But I’d really like to have Z-Push as well, and that only seems to be available if you switch completely to Kopano.
Thanks
–Dan
Hi @fluidmindorg,
the z-push app in the Appcenter is indeed only designed to work with Kopano. If you want to use it with a different configuration you have to install it manually (like explained in the z-push wiki).
Thanks @fbartels. I’ll give that a try. I’ll have to install Roundcube manually anyway, so I may as well install Z-Push that way too. I just wanted to check if anyone had already tried that and had run into any problems. I’ll give it a try and report the results in case anyone else wants to do such a thing.
Cheers
–Dan
