You have a cool solution repository integrated
Please check <http://wiki.univention.de/index.php?title=Category:Cool_Solutions>
if the Cool Solution is already available for UCS 4.4-0.
Now I have the following Packages Cool-Solution packages installed:
grep ^Package: /var/lib/apt/lists/updates.software-univention.de_*.*_unmaintained_component_cool-solutions_all_Packages -h | sort --unique
Package: geoip-database
Package: geoip-database-contrib
Package: geoip-database-extra
Package: guacamole
Package: guacamole-tomcat
Package: libcache-memcached-perl
Package: libclass-tiny-perl
Package: libconfig-general-perl
Package: libdevel-partialdump-perl
Package: libmoosex-singleton-perl
Package: libnamespace-autoclean-perl
Package: libtime-piece-mysql-perl
Package: libvirt-wakeonlan
Package: univention-automx
Package: univention-bind-blacklist
Package: univention-custom-ldap-acls
Package: univention-custom-ldap-acls-schema
Package: univention-demo-data
Package: univention-domain-userquota
Package: univention-domain-userquota-schema
Package: univention-domain-userquota-school-acl
Package: univention-dovecot-migration
Package: univention-fail2ban-config-ransomware
Package: univention-guacamole-rollout
Package: univention-guacamole-schema
Package: univention-homedir-autocreate
Package: univention-ldap-restore
Package: univention-ldap-usercert
Package: univention-letsencrypt
Package: univention-mtpolicyd
Package: univention-munin-node
Package: univention-munin-server
Package: univention-nextcloud-enable-for-classes-and-workgroups
Package: univention-nextcloud-samba-common
Package: univention-nextcloud-samba-common-share-config
Package: univention-nextcloud-samba-group-share-config
Package: univention-nextcloud-samba-home-share-config
Package: univention-pam
Package: univention-printer-assignment
Package: univention-printer-assignment-schema
Package: univention-set-samba4-profile-path
Package: univention-shalla-list-downloader
Package: univention-sudo-ldap
Package: univention-sudo-ldap-host
Package: univention-sudo-ldap-schema
Package: univention-ucc-status-integration
Package: univention-usercert
Package: univention-user-group-sync-dest
Package: univention-user-group-sync-sink
Package: univention-user-group-sync-source
Package: univention-wakeonlan
Package: univention-windowscert
But how to figure out, if they are available in 4.4?
Thx a lot,
meg
Seems except univention-user-group-sync none is available for 4.4. So is it save to upgrade?
Did this just mean the features (like usercerts,letsencrypt) disappear (and reappear when they are available for 4.4) or could an upgrade result in major problems?
As far as I remember I’m only using certs and custom ldap ACLs
Regarding to this I’ve just have to check the wiki, not the repository, correct?
