XWiki not available?
Hi, I have installed XWiki last year on a univention server without a problem. I was trying to do the same yesterday (and today), but via the App-Center I always get the message: “error trying to contact server, try again later”. I tried to install it via apt-get but it seems to be missing from the repositories?
Can you give a hint how I will be able to install and use XWiki again?
If it is only available on older UCS versions, that would be okay - am I able to get virtualbox images of older UCS versions? If there are repositories where XWiki is still available, can you point me to it?
Thanks in advance!
Okay, sorry - venting some frustration here. Why is XWiki still in the app-store? It has a dependance, that is not solvable without “cheating” and after successfull installing and implementing all the Plugins, you cannot even use the “log-in” button → it just end in “ucs-sso.xxx.xxx is not reachable”. Sorry, what is this? I know in the past you could for the most time rely on UCS. Now, even in the App section of the forum no one cares for issues of users.
really not up to standards anymore.
Same thoughts here…!
