Good Afternoon
My wordpress site on the univention platform has come up with the following error, any ideas on how to fix?
Composer detected issues in your platform: Your Composer dependencies require a PHP version “>= 8.0.0”.
Thanks
David
Good Afternoon
Thanks
David
Sounds like you updated Wordpress to a version that has a Composer version that requires PHP 8 or more.
If I remember correctly, php 8 will be available in Univention 5.2.
So you can either downgrade your wordpress for now or look for a way to manually install php 8 (and not break anything else in univention).
Ive only just updated the univention software, not wordpress unless it did itself automattically.
Ill look at downgrading wordpress thanks
