Hi guys
I setup a simple test network compounded by a
- wired client (mac)
- a wireless client (my smartphone)
- a switch
- an accesspoint/router running dd-wrt with an internet connection with local ip address: 10.0.0.1 with ssd: fcortesWLAN
- a univention dc, dhcp, radius server with local ip address 10.0.0.2 (freshly installed with 4.3-1 errata151)
- a domain user with username: fcortes with allowed network access under radius in the umc console
When tryng to authenticate to access the wireless network fcortesWLAN with a wireless node I can’t seem to be able to join the network after entering username: fcortes and respective password.
items checked/configuration:
my access point (10.0.0.1) has this configuration
clients.conf on 10.0.0.2 (univention radius server)
my network user “fcortes” is allowed:
freeradius shows active and waiting for request:
5.radius.log shows no apparent issues:
comments:
I tried to enable authentication logging but I see no loging attempts good or bad in the radius.log
I understand that certs might be needed to be setup on server so proper authentication is done although I haven’t found instructions on how to do this part in the manual (if I missed it I would appreciate your guidance on this part).
here’s the freeradius -X -f if it provides some info:
root@optiplexmint:/var/log/freeradius# freeradius -X -f
FreeRADIUS Version 3.0.12
Copyright (C) 1999-2016 The FreeRADIUS server project and contributors
There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE
You may redistribute copies of FreeRADIUS under the terms of the
GNU General Public License
For more information about these matters, see the file named COPYRIGHT
Starting - reading configuration files ...
including dictionary file /usr/share/freeradius/dictionary
including dictionary file /usr/share/freeradius/dictionary.dhcp
including dictionary file /usr/share/freeradius/dictionary.vqp
including dictionary file /etc/freeradius/3.0/dictionary
including configuration file /etc/freeradius/3.0/radiusd.conf
including configuration file /etc/freeradius/3.0/proxy.conf
including configuration file /etc/freeradius/3.0/clients.conf
including files in directory /etc/freeradius/3.0/mods-enabled/
including configuration file /etc/freeradius/3.0/mods-enabled/unpack
including configuration file /etc/freeradius/3.0/mods-enabled/exec
including configuration file /etc/freeradius/3.0/mods-enabled/echo
including configuration file /etc/freeradius/3.0/mods-enabled/ntlm_auth
including configuration file /etc/freeradius/3.0/mods-enabled/files
including configuration file /etc/freeradius/3.0/mods-enabled/realm
including configuration file /etc/freeradius/3.0/mods-enabled/linelog
including configuration file /etc/freeradius/3.0/mods-enabled/attr_filter
including configuration file /etc/freeradius/3.0/mods-enabled/radutmp
including configuration file /etc/freeradius/3.0/mods-enabled/ldap
including configuration file /etc/freeradius/3.0/mods-enabled/pap
including configuration file /etc/freeradius/3.0/mods-enabled/utf8
including configuration file /etc/freeradius/3.0/mods-enabled/cache_eap
including configuration file /etc/freeradius/3.0/mods-enabled/always
including configuration file /etc/freeradius/3.0/mods-enabled/mschap
including configuration file /etc/freeradius/3.0/mods-enabled/detail.log
including configuration file /etc/freeradius/3.0/mods-enabled/preprocess
including configuration file /etc/freeradius/3.0/mods-enabled/digest
including configuration file /etc/freeradius/3.0/mods-enabled/passwd
including configuration file /etc/freeradius/3.0/mods-enabled/replicate
including configuration file /etc/freeradius/3.0/mods-enabled/expiration
including configuration file /etc/freeradius/3.0/mods-enabled/sradutmp
including configuration file /etc/freeradius/3.0/mods-enabled/expr
including configuration file /etc/freeradius/3.0/mods-enabled/chap
including configuration file /etc/freeradius/3.0/mods-enabled/eap
including configuration file /etc/freeradius/3.0/mods-enabled/dynamic_clients
including configuration file /etc/freeradius/3.0/mods-enabled/unix
including configuration file /etc/freeradius/3.0/mods-enabled/soh
including configuration file /etc/freeradius/3.0/mods-enabled/logintime
including files in directory /etc/freeradius/3.0/policy.d/
including configuration file /etc/freeradius/3.0/policy.d/dhcp
including configuration file /etc/freeradius/3.0/policy.d/filter
including configuration file /etc/freeradius/3.0/policy.d/operator-name
including configuration file /etc/freeradius/3.0/policy.d/control
including configuration file /etc/freeradius/3.0/policy.d/canonicalization
including configuration file /etc/freeradius/3.0/policy.d/debug
including configuration file /etc/freeradius/3.0/policy.d/moonshot-targeted-ids
including configuration file /etc/freeradius/3.0/policy.d/abfab-tr
including configuration file /etc/freeradius/3.0/policy.d/accounting
including configuration file /etc/freeradius/3.0/policy.d/eap
including configuration file /etc/freeradius/3.0/policy.d/cui
including files in directory /etc/freeradius/3.0/sites-enabled/
including configuration file /etc/freeradius/3.0/sites-enabled/default
including configuration file /etc/freeradius/3.0/sites-enabled/inner-tunnel
main {
security {
user = "freerad"
group = "freerad"
allow_core_dumps = no
name = "freeradius"
prefix = "/usr"
localstatedir = "/var"
logdir = "/var/log/freeradius"
run_dir = "/var/run/freeradius"
main {
name = "freeradius"
prefix = "/usr"
sbindir = "/usr/sbin"
libdir = "/usr/lib/freeradius"
radacctdir = "/var/log/freeradius/radacct"
hostname_lookups = no
max_request_time = 30
cleanup_delay = 5
max_requests = 1024
pidfile = "/var/run/freeradius/freeradius.pid"
checkrad = "/usr/sbin/checkrad"
debug_level = 0
proxy_requests = yes
log {
stripped_names = yes
auth = yes
auth_badpass = yes
auth_goodpass = no
colourise = yes
msg_denied = "You are already logged in - access denied"
resources {
security {
max_attributes = 200
reject_delay = 1.000000
status_server = yes
radiusd: #### Loading Realms and Home Servers ####
proxy server {
retry_delay = 5
retry_count = 3
default_fallback = no
dead_time = 120
wake_all_if_all_dead = no
home_server localhost {
ipaddr = 127.0.0.1
port = 1812
type = "auth"
secret = <<< secret >>>
response_window = 20.000000
response_timeouts = 1
max_outstanding = 65536
zombie_period = 40
status_check = "status-server"
ping_interval = 30
check_interval = 30
check_timeout = 4
num_answers_to_alive = 3
revive_interval = 120
limit {
max_connections = 16
max_requests = 0
lifetime = 0
idle_timeout = 0
coa {
irt = 2
mrt = 16
mrc = 5
mrd = 30
home_server_pool my_auth_failover {
type = fail-over
home_server = localhost
realm example.com {
auth_pool = my_auth_failover
realm LOCAL {
radiusd: #### Loading Clients ####
client localhost {
ipaddr = 127.0.0.1
require_message_authenticator = no
nas_type = "other"
proto = "*"
limit {
lifetime = 0
idle_timeout = 30
client localhost_ipv6 {
ipv6addr = ::1
limit {
lifetime = 0
idle_timeout = 30
client 10.0.0.1 {
ipaddr = 10.0.0.1
shortname = "DD-WRT"
limit {
lifetime = 0
idle_timeout = 30
Debugger not attached
# Creating Auth-Type = eap
# Creating Auth-Type = PAP
# Creating Auth-Type = CHAP
# Creating Auth-Type = MS-CHAP
# Creating Auth-Type = LDAP
radiusd: #### Instantiating modules ####
modules {
# Loaded module rlm_unpack
# Loading module "unpack" from file /etc/freeradius/3.0/mods-enabled/unpack
# Loaded module rlm_exec
# Loading module "exec" from file /etc/freeradius/3.0/mods-enabled/exec
exec {
wait = no
input_pairs = "request"
shell_escape = yes
timeout = 10
# Loading module "echo" from file /etc/freeradius/3.0/mods-enabled/echo
exec echo {
wait = yes
program = "/bin/echo %{User-Name}"
output_pairs = "reply"
shell_escape = yes
# Loading module "ntlm_auth" from file /etc/freeradius/3.0/mods-enabled/ntlm_auth
exec ntlm_auth {
wait = yes
program = "/path/to/ntlm_auth --request-nt-key --domain=MYDOMAIN --username=%{mschap:User-Name} --password=%{User-Password}"
shell_escape = yes
# Loaded module rlm_files
# Loading module "files" from file /etc/freeradius/3.0/mods-enabled/files
files {
filename = "/etc/freeradius/3.0/mods-config/files/authorize"
acctusersfile = "/etc/freeradius/3.0/mods-config/files/accounting"
preproxy_usersfile = "/etc/freeradius/3.0/mods-config/files/pre-proxy"
# Loaded module rlm_realm
# Loading module "IPASS" from file /etc/freeradius/3.0/mods-enabled/realm
realm IPASS {
format = "prefix"
delimiter = "/"
ignore_default = no
ignore_null = no
# Loading module "suffix" from file /etc/freeradius/3.0/mods-enabled/realm
realm suffix {
format = "suffix"
delimiter = "@"
ignore_default = no
ignore_null = no
# Loading module "realmpercent" from file /etc/freeradius/3.0/mods-enabled/realm
realm realmpercent {
format = "suffix"
delimiter = "%"
ignore_default = no
ignore_null = no
# Loading module "ntdomain" from file /etc/freeradius/3.0/mods-enabled/realm
realm ntdomain {
format = "prefix"
delimiter = "\\"
ignore_default = no
ignore_null = no
# Loaded module rlm_linelog
# Loading module "linelog" from file /etc/freeradius/3.0/mods-enabled/linelog
linelog {
filename = "/var/log/freeradius/linelog"
escape_filenames = no
syslog_severity = "info"
permissions = 384
format = "This is a log message for %{User-Name}"
reference = "messages.%{%{reply:Packet-Type}:-default}"
# Loading module "log_accounting" from file /etc/freeradius/3.0/mods-enabled/linelog
linelog log_accounting {
filename = "/var/log/freeradius/linelog-accounting"
permissions = 384
format = ""
reference = "Accounting-Request.%{%{Acct-Status-Type}:-unknown}"
# Loaded module rlm_attr_filter
# Loading module "attr_filter.post-proxy" from file /etc/freeradius/3.0/mods-enabled/attr_filter
attr_filter attr_filter.post-proxy {
filename = "/etc/freeradius/3.0/mods-config/attr_filter/post-proxy"
key = "%{Realm}"
relaxed = no
# Loading module "attr_filter.pre-proxy" from file /etc/freeradius/3.0/mods-enabled/attr_filter
attr_filter attr_filter.pre-proxy {
filename = "/etc/freeradius/3.0/mods-config/attr_filter/pre-proxy"
key = "%{Realm}"
relaxed = no
# Loading module "attr_filter.access_reject" from file /etc/freeradius/3.0/mods-enabled/attr_filter
attr_filter attr_filter.access_reject {
filename = "/etc/freeradius/3.0/mods-config/attr_filter/access_reject"
key = "%{User-Name}"
relaxed = no
# Loading module "attr_filter.access_challenge" from file /etc/freeradius/3.0/mods-enabled/attr_filter
attr_filter attr_filter.access_challenge {
filename = "/etc/freeradius/3.0/mods-config/attr_filter/access_challenge"
relaxed = no
# Loading module "attr_filter.accounting_response" from file /etc/freeradius/3.0/mods-enabled/attr_filter
attr_filter attr_filter.accounting_response {
filename = "/etc/freeradius/3.0/mods-config/attr_filter/accounting_response"
relaxed = no
# Loaded module rlm_radutmp
# Loading module "radutmp" from file /etc/freeradius/3.0/mods-enabled/radutmp
radutmp {
filename = "/var/log/freeradius/radutmp"
username = "%{User-Name}"
case_sensitive = yes
check_with_nas = yes
permissions = 384
caller_id = yes
# Loaded module rlm_ldap
# Loading module "ldap" from file /etc/freeradius/3.0/mods-enabled/ldap
ldap {
server = "optiplexmint.copesal.local"
port = 7389
identity = "cn=optiplexmint,cn=dc,cn=computers,dc=copesal,dc=local"
password = <<< secret >>>
sasl {
user {
scope = "sub"
access_positive = yes
sasl {
group {
filter = "(objectClass=posixGroup)"
scope = "sub"
name_attribute = "cn"
membership_attribute = "memberOf"
cacheable_name = no
cacheable_dn = no
client {
filter = "(objectClass=radiusClient)"
scope = "sub"
base_dn = "dc=copesal,dc=local"
profile {
options {
ldap_debug = 40
chase_referrals = yes
rebind = yes
net_timeout = 1
res_timeout = 10
srv_timelimit = 3
idle = 60
probes = 3
interval = 3
tls {
start_tls = yes
Creating attribute LDAP-Group
# Loaded module rlm_pap
# Loading module "pap" from file /etc/freeradius/3.0/mods-enabled/pap
pap {
normalise = yes
# Loaded module rlm_utf8
# Loading module "utf8" from file /etc/freeradius/3.0/mods-enabled/utf8
# Loaded module rlm_cache
# Loading module "cache_eap" from file /etc/freeradius/3.0/mods-enabled/cache_eap
cache cache_eap {
driver = "rlm_cache_rbtree"
key = "%{%{control:State}:-%{%{reply:State}:-%{State}}}"
ttl = 15
max_entries = 0
epoch = 0
add_stats = no
# Loaded module rlm_always
# Loading module "reject" from file /etc/freeradius/3.0/mods-enabled/always
always reject {
rcode = "reject"
simulcount = 0
mpp = no
# Loading module "fail" from file /etc/freeradius/3.0/mods-enabled/always
always fail {
rcode = "fail"
simulcount = 0
mpp = no
# Loading module "ok" from file /etc/freeradius/3.0/mods-enabled/always
always ok {
rcode = "ok"
simulcount = 0
mpp = no
# Loading module "handled" from file /etc/freeradius/3.0/mods-enabled/always
always handled {
rcode = "handled"
simulcount = 0
mpp = no
# Loading module "invalid" from file /etc/freeradius/3.0/mods-enabled/always
always invalid {
rcode = "invalid"
simulcount = 0
mpp = no
# Loading module "userlock" from file /etc/freeradius/3.0/mods-enabled/always
always userlock {
rcode = "userlock"
simulcount = 0
mpp = no
# Loading module "notfound" from file /etc/freeradius/3.0/mods-enabled/always
always notfound {
rcode = "notfound"
simulcount = 0
mpp = no
# Loading module "noop" from file /etc/freeradius/3.0/mods-enabled/always
always noop {
rcode = "noop"
simulcount = 0
mpp = no
# Loading module "updated" from file /etc/freeradius/3.0/mods-enabled/always
always updated {
rcode = "updated"
simulcount = 0
mpp = no
# Loaded module rlm_mschap
# Loading module "mschap" from file /etc/freeradius/3.0/mods-enabled/mschap
mschap {
use_mppe = yes
require_encryption = yes
require_strong = yes
with_ntdomain_hack = yes
ntlm_auth = "/usr/bin/univention-radius-ntlm-auth-suidwrapper --request-nt-key --username=%{%{Stripped-User-Name}:-%{%{User-Name}:-None}} --challenge=%{%{mschap:Challenge}:-00} --nt-response=%{%{mschap:NT-Response}:-00} --station-id=%{outer.request:Calling-Station-Id}"
passchange {
allow_retry = yes
# Loaded module rlm_detail
# Loading module "auth_log" from file /etc/freeradius/3.0/mods-enabled/detail.log
detail auth_log {
filename = "/var/log/freeradius/radacct/%{%{Packet-Src-IP-Address}:-%{Packet-Src-IPv6-Address}}/auth-detail-%Y%m%d"
header = "%t"
permissions = 384
locking = no
log_packet_header = no
# Loading module "reply_log" from file /etc/freeradius/3.0/mods-enabled/detail.log
detail reply_log {
filename = "/var/log/freeradius/radacct/%{%{Packet-Src-IP-Address}:-%{Packet-Src-IPv6-Address}}/reply-detail-%Y%m%d"
header = "%t"
permissions = 384
locking = no
# Loading module "pre_proxy_log" from file /etc/freeradius/3.0/mods-enabled/detail.log
detail pre_proxy_log {
filename = "/var/log/freeradius/radacct/%{%{Packet-Src-IP-Address}:-%{Packet-Src-IPv6-Address}}/pre-proxy-detail-%Y%m%d"
header = "%t"
permissions = 384
locking = no
# Loading module "post_proxy_log" from file /etc/freeradius/3.0/mods-enabled/detail.log
detail post_proxy_log {
filename = "/var/log/freeradius/radacct/%{%{Packet-Src-IP-Address}:-%{Packet-Src-IPv6-Address}}/post-proxy-detail-%Y%m%d"
header = "%t"
permissions = 384
locking = no
# Loaded module rlm_preprocess
# Loading module "preprocess" from file /etc/freeradius/3.0/mods-enabled/preprocess
preprocess {
huntgroups = "/etc/freeradius/3.0/mods-config/preprocess/huntgroups"
hints = "/etc/freeradius/3.0/mods-config/preprocess/hints"
with_ascend_hack = no
ascend_channels_per_line = 23
with_ntdomain_hack = no
with_specialix_jetstream_hack = no
with_cisco_vsa_hack = no
with_alvarion_vsa_hack = no
# Loaded module rlm_digest
# Loading module "digest" from file /etc/freeradius/3.0/mods-enabled/digest
# Loaded module rlm_passwd
# Loading module "etc_passwd" from file /etc/freeradius/3.0/mods-enabled/passwd
passwd etc_passwd {
filename = "/etc/passwd"
format = "*User-Name:Crypt-Password:"
delimiter = ":"
ignore_nislike = no
ignore_empty = yes
allow_multiple_keys = no
hash_size = 100
# Loaded module rlm_replicate
# Loading module "replicate" from file /etc/freeradius/3.0/mods-enabled/replicate
# Loaded module rlm_expiration
# Loading module "expiration" from file /etc/freeradius/3.0/mods-enabled/expiration
# Loading module "sradutmp" from file /etc/freeradius/3.0/mods-enabled/sradutmp
radutmp sradutmp {
filename = "/var/log/freeradius/sradutmp"
permissions = 420
caller_id = no
# Loading module "detail" from file /etc/freeradius/3.0/mods-enabled/detail
detail {
filename = "/var/log/freeradius/radacct/%{%{Packet-Src-IP-Address}:-%{Packet-Src-IPv6-Address}}/detail-%Y%m%d"
header = "%t"
permissions = 384
locking = no
# Loaded module rlm_expr
# Loading module "expr" from file /etc/freeradius/3.0/mods-enabled/expr
expr {
safe_characters = "@abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789.-_: /äéöüàâæçèéêëîïôœùûüaÿÄÉÖÜßÀÂÆÇÈÉÊËÎÏÔŒÙÛÜŸ"
# Loaded module rlm_chap
# Loading module "chap" from file /etc/freeradius/3.0/mods-enabled/chap
# Loaded module rlm_eap
# Loading module "eap" from file /etc/freeradius/3.0/mods-enabled/eap
eap {
default_eap_type = "peap"
timer_expire = 60
ignore_unknown_eap_types = no
cisco_accounting_username_bug = no
max_sessions = 1024
# Loaded module rlm_dynamic_clients
# Loading module "dynamic_clients" from file /etc/freeradius/3.0/mods-enabled/dynamic_clients
# Loaded module rlm_unix
# Loading module "unix" from file /etc/freeradius/3.0/mods-enabled/unix
unix {
radwtmp = "/var/log/freeradius/radwtmp"
Creating attribute Unix-Group
# Loaded module rlm_soh
# Loading module "soh" from file /etc/freeradius/3.0/mods-enabled/soh
soh {
dhcp = yes
# Loaded module rlm_logintime
# Loading module "logintime" from file /etc/freeradius/3.0/mods-enabled/logintime
logintime {
minimum_timeout = 60
instantiate {
# Instantiating module "files" from file /etc/freeradius/3.0/mods-enabled/files
reading pairlist file /etc/freeradius/3.0/mods-config/files/authorize
reading pairlist file /etc/freeradius/3.0/mods-config/files/accounting
reading pairlist file /etc/freeradius/3.0/mods-config/files/pre-proxy
# Instantiating module "IPASS" from file /etc/freeradius/3.0/mods-enabled/realm
# Instantiating module "suffix" from file /etc/freeradius/3.0/mods-enabled/realm
# Instantiating module "realmpercent" from file /etc/freeradius/3.0/mods-enabled/realm
# Instantiating module "ntdomain" from file /etc/freeradius/3.0/mods-enabled/realm
# Instantiating module "linelog" from file /etc/freeradius/3.0/mods-enabled/linelog
# Instantiating module "log_accounting" from file /etc/freeradius/3.0/mods-enabled/linelog
# Instantiating module "attr_filter.post-proxy" from file /etc/freeradius/3.0/mods-enabled/attr_filter
reading pairlist file /etc/freeradius/3.0/mods-config/attr_filter/post-proxy
# Instantiating module "attr_filter.pre-proxy" from file /etc/freeradius/3.0/mods-enabled/attr_filter
reading pairlist file /etc/freeradius/3.0/mods-config/attr_filter/pre-proxy
# Instantiating module "attr_filter.access_reject" from file /etc/freeradius/3.0/mods-enabled/attr_filter
reading pairlist file /etc/freeradius/3.0/mods-config/attr_filter/access_reject
[/etc/freeradius/3.0/mods-config/attr_filter/access_reject]:11 Check item "FreeRADIUS-Response-Delay" found in filter list for realm "DEFAULT".
[/etc/freeradius/3.0/mods-config/attr_filter/access_reject]:11 Check item "FreeRADIUS-Response-Delay-USec" found in filter list for realm "DEFAULT".
# Instantiating module "attr_filter.access_challenge" from file /etc/freeradius/3.0/mods-enabled/attr_filter
reading pairlist file /etc/freeradius/3.0/mods-config/attr_filter/access_challenge
# Instantiating module "attr_filter.accounting_response" from file /etc/freeradius/3.0/mods-enabled/attr_filter
reading pairlist file /etc/freeradius/3.0/mods-config/attr_filter/accounting_response
# Instantiating module "ldap" from file /etc/freeradius/3.0/mods-enabled/ldap
rlm_ldap: libldap vendor: OpenLDAP, version: 20445
accounting {
reference = "%{tolower:type.%{Acct-Status-Type}}"
post-auth {
reference = "."
rlm_ldap (ldap): Initialising connection pool
pool {
start = 5
min = 3
max = 32
spare = 10
uses = 0
lifetime = 0
cleanup_interval = 30
idle_timeout = 60
retry_delay = 30
spread = no
rlm_ldap (ldap): Opening additional connection (0), 1 of 32 pending slots used
rlm_ldap (ldap): Connecting to ldap://optiplexmint.copesal.local:7389
rlm_ldap (ldap): Waiting for bind result...
rlm_ldap (ldap): Bind successful
rlm_ldap (ldap): Opening additional connection (1), 1 of 31 pending slots used
rlm_ldap (ldap): Opening additional connection (2), 1 of 30 pending slots used
rlm_ldap (ldap): Opening additional connection (3), 1 of 29 pending slots used
rlm_ldap (ldap): Opening additional connection (4), 1 of 28 pending slots used
# Instantiating module "pap" from file /etc/freeradius/3.0/mods-enabled/pap
# Instantiating module "cache_eap" from file /etc/freeradius/3.0/mods-enabled/cache_eap
rlm_cache (cache_eap): Driver rlm_cache_rbtree (module rlm_cache_rbtree) loaded and linked
# Instantiating module "reject" from file /etc/freeradius/3.0/mods-enabled/always
# Instantiating module "fail" from file /etc/freeradius/3.0/mods-enabled/always
# Instantiating module "ok" from file /etc/freeradius/3.0/mods-enabled/always
# Instantiating module "handled" from file /etc/freeradius/3.0/mods-enabled/always
# Instantiating module "invalid" from file /etc/freeradius/3.0/mods-enabled/always
# Instantiating module "userlock" from file /etc/freeradius/3.0/mods-enabled/always
# Instantiating module "notfound" from file /etc/freeradius/3.0/mods-enabled/always
# Instantiating module "noop" from file /etc/freeradius/3.0/mods-enabled/always
# Instantiating module "updated" from file /etc/freeradius/3.0/mods-enabled/always
# Instantiating module "mschap" from file /etc/freeradius/3.0/mods-enabled/mschap
rlm_mschap (mschap): authenticating by calling 'ntlm_auth'
# Instantiating module "auth_log" from file /etc/freeradius/3.0/mods-enabled/detail.log
rlm_detail (auth_log): 'User-Password' suppressed, will not appear in detail output
# Instantiating module "reply_log" from file /etc/freeradius/3.0/mods-enabled/detail.log
# Instantiating module "pre_proxy_log" from file /etc/freeradius/3.0/mods-enabled/detail.log
# Instantiating module "post_proxy_log" from file /etc/freeradius/3.0/mods-enabled/detail.log
# Instantiating module "preprocess" from file /etc/freeradius/3.0/mods-enabled/preprocess
reading pairlist file /etc/freeradius/3.0/mods-config/preprocess/huntgroups
reading pairlist file /etc/freeradius/3.0/mods-config/preprocess/hints
# Instantiating module "etc_passwd" from file /etc/freeradius/3.0/mods-enabled/passwd
rlm_passwd: nfields: 3 keyfield 0(User-Name) listable: no
# Instantiating module "expiration" from file /etc/freeradius/3.0/mods-enabled/expiration
# Instantiating module "detail" from file /etc/freeradius/3.0/mods-enabled/detail
# Instantiating module "eap" from file /etc/freeradius/3.0/mods-enabled/eap
# Linked to sub-module rlm_eap_md5
# Linked to sub-module rlm_eap_leap
# Linked to sub-module rlm_eap_gtc
gtc {
challenge = "Password: "
auth_type = "PAP"
# Linked to sub-module rlm_eap_tls
tls {
tls = "tls-common"
tls-config tls-common {
verify_depth = 0
ca_path = "/etc/freeradius/3.0/certs"
pem_file_type = yes
private_key_file = "/etc/freeradius/ssl/private.key"
certificate_file = "/etc/freeradius/ssl/cert.pem"
ca_file = "/etc/univention/ssl/ucsCA/CAcert.pem"
dh_file = "/etc/freeradius/3.0/certs/dh"
fragment_size = 1024
include_length = yes
auto_chain = yes
check_crl = no
check_all_crl = no
cipher_list = "DEFAULT"
ecdh_curve = "prime256v1"
cache {
enable = yes
lifetime = 24
max_entries = 255
verify {
skip_if_ocsp_ok = no
ocsp {
enable = no
override_cert_url = yes
url = "http://127.0.0.1/ocsp/"
use_nonce = yes
timeout = 0
softfail = no
# Linked to sub-module rlm_eap_peap
peap {
tls = "tls-common"
default_eap_type = "mschapv2"
copy_request_to_tunnel = no
use_tunneled_reply = no
proxy_tunneled_request_as_eap = yes
virtual_server = "inner-tunnel"
soh = no
require_client_cert = no
tls: Using cached TLS configuration from previous invocation
# Linked to sub-module rlm_eap_mschapv2
mschapv2 {
send_error = no
# Instantiating module "logintime" from file /etc/freeradius/3.0/mods-enabled/logintime
} # modules
radiusd: #### Loading Virtual Servers ####
server { # from file /etc/freeradius/3.0/radiusd.conf
} # server
server default { # from file /etc/freeradius/3.0/sites-enabled/default
# Loading authenticate {...}
# Loading authorize {...}
# Loading preacct {...}
# Loading accounting {...}
Ignoring "sql" (see raddb/mods-available/README.rst)
# Loading post-proxy {...}
# Loading post-auth {...}
} # server default
server inner-tunnel { # from file /etc/freeradius/3.0/sites-enabled/inner-tunnel
# Loading session {...}
} # server inner-tunnel
radiusd: #### Opening IP addresses and Ports ####
listen {
type = "auth"
ipaddr = *
port = 0
limit {
lifetime = 0
idle_timeout = 30
Failed binding to auth address * port 1812 bound to server default: Address already in use
/etc/freeradius/3.0/sites-enabled/default[68]: Error binding to port for 0.0.0.0 port 1812
