Danke.
Nach erfolgter Konfiguration der entsprechen Datein erscheint folgende Fehlermeldung
2008-04-15 12:34:15 [7143] squidGuard 1.2.0 started (1208255654.651)
2008-04-15 12:34:15 [7143] db update done
2008-04-15 12:34:15 [7143] squidGuard stopped (1208255655.247)
2008-04-15 12:44:16 [7806] init domainlist /var/lib/squidguard/db/xxx/domains
2008-04-15 12:44:16 [7806] loading dbfile /var/lib/squidguard/db/xxx/domains.db
2008-04-15 12:44:16 [7806] Error db_open: Permission denied
2008-04-15 12:44:16 [7807] init domainlist /var/lib/squidguard/db/xxx/domains
2008-04-15 12:44:16 [7807] loading dbfile /var/lib/squidguard/db/xxx/domains.db
2008-04-15 12:44:16 [7807] Error db_open: Permission denied
2008-04-15 12:44:16 [7808] init domainlist /var/lib/squidguard/db/xxx/domains
2008-04-15 12:44:16 [7808] loading dbfile /var/lib/squidguard/db/xxx/domains.db
2008-04-15 12:44:16 [7808] Error db_open: Permission denied
2008-04-15 12:44:16 [7809] init domainlist /var/lib/squidguard/db/xxx/domains
2008-04-15 12:44:16 [7809] loading dbfile /var/lib/squidguard/db/xxx/domains.db
2008-04-15 12:44:16 [7809] Error db_open: Permission denied
2008-04-15 12:44:16 [7810] init domainlist /var/lib/squidguard/db/xxx/domains
2008-04-15 12:44:16 [7810] loading dbfile /var/lib/squidguard/db/xxx/domains.db
2008-04-15 12:44:16 [7810] Error db_open: Permission denied
2008-04-15 12:44:16 [7811] init domainlist /var/lib/squidguard/db/xxx/domains
2008-04-15 12:44:16 [7811] loading dbfile /var/lib/squidguard/db/xxx/domains.db
2008-04-15 12:44:16 [7811] Error db_open: Permission denied
2008-04-15 12:44:16 [7812] init domainlist /var/lib/squidguard/db/xxx/domains
In der /etc/squid/squid.conf ist zusätzlich diese Zeile hinzugefügt
redirect_program /usr/bin/squidGuard -c /etc/squid/squidGuard.conf
Wenn ich auf der Kommandozeile dies ausführe:
root@dmoeko:/var/lib/squidguard/db# echo "http://www.ebay.de 192.168.2.187/ - - GET" | squidGuard -c /etc/squid/squidGuard.conf
http://www.oekonet-bremen.de 192.168.2.187/- - -
Dann wird der Eintrag aus /var/lib/squidguard/db/auktionen/domains ausgewertet und die Domain ebay.de dementsprechend umgeleitet. Nur im Browser funktioniert es nicht. Was könnte die Ursache dafür sein?
MfG
