chrome-dev drops an ssl error because usage of SHA1
Please fix it
Please fix it
Ouch. Paging @ahrens + @TimoDenissen.
In the meanwhile, I recommend to use https://docs.software-univention.de - that’s the “correct” URL for quite some time and afaik https://docs.univention.de only redirects there anyway.
Best regards,
Michael Grandjean
It redirect to the right url, yes.
But only if i accept the warning
Hello npanic,
thanks for the info and your watchful eye
We changed the certificate and implemented a new one, which meets the requirements of all modern web-browsers.
Kind regards, Stefan Ahrens / Univention.
