WARNING: 1 join scripts have to be called
Current Status:
WARNING
Status Information: WARNING: 1 join scripts have to be called
gibt es dafür eine Behebung?
ucr search ^version
version/patchlevel: 3
version/releasename: copper beech
version/security-patchlevel: 5
version/version: 2.2
LG
Franz
diese Frage wurde bereits im Thread Nagios bemängelt Join-Skipte beantwortet.
Janis Meybohm
[code]univention-run-join-scripts
copyright © 2001-2008 Univention GmbH, Germany
Running 01univention-ldap-server-init.inst (exitcode 1)
Running 02univention-directory-notifier.inst (exitcode 1)
Running 03univention-directory-listener.inst (exitcode 1)
Running 04univention-ldap-client.inst (exitcode 1)
Running 05univention-bind.inst (exitcode 1)
Running 08univention-apache.inst (exitcode 1)
Running 10univention-ldap-server.inst (exitcode 1)
Running 11univention-heimdal-init.inst (exitcode 1)
Running 15univention-directory-notifier-post.inst (exitcode 1)
Running 15univention-heimdal-kdc.inst (exitcode 1)
Running 20univention-directory-policy.inst (exitcode 1)
Running 25univention-dhcp.inst (exitcode 1)
Running 25univention-directory-manager.inst (exitcode 1)
Running 26univention-nagios-server.inst (exitcode 1)
Running 26univention-samba.inst (exitcode 1)
Running 30univention-nagios-client.inst (exitcode 1)
Running 34univention-management-console-server.inst (exitcode 1)
Running 41univention-updater.inst (exitcode 1)
Running 50univention-pkgdb.inst (exitcode 1)
Running 66univention-scalix.inst (exitcode 1)
Running 68univention-spamassassin.inst done
Running 71univention-quota.inst (exitcode 1)
Running 81univention-nfs-server.inst (exitcode 1)
Running 81univention-server-installation.inst (exitcode 1)
Running 90univention-bind-proxy.inst (exitcode 1)
Running 91univention-client-boot-pxe.inst (exitcode 1)
Running 91univention-join.inst (exitcode 1)
Running 98univention-pkgdb-tools.inst (exitcode 1)
root@sbsrv:/# univention-run-join-scripts
Running 68univention-spamassassin.inst (exitcode 1)
[/code]
Das War noch nicht die Lösung meines Problems :slight_smile:
[code]
UNIVENTION_JOINSTATUS
WARNING 	2010-07-05 15:33:18 	8d 2h 18m 11s 	1/1 	WARNING: 1 join scripts have to be called [/code]
Danke
LG
Franz
[2010-07-06 15:33:28] SERVICE ALERT: sbsrv.kreibich.local;UNIVENTION_JOINSTATUS;OK;HARD;1;OK: system joined successfully
Die Zeit heilt alle Wunden ^^ g
LG
Franz
da Nagios die Checks in Intervallen ausführt ist es völlig normal das die Statusänderung nicht “sofort” zu sehen ist.
Janis Meybohm
Für mich und auch für Andere wäre es sicher interessant wann diese stattfinden?
Habe versucht das ganze zu beschleunigen in dem ich den nrpe-server neu gestartet habe.
LG
Franz
ein Blick in die Scheduling Queue des Nagios Webinterface sollte hier Aufschluss geben ( univention.de/download/dokum … istration/ ).
Janis Meybohm
um das sofort zu pruefen kann man das Plugin auch selbst ausfuehren:
/usr/lib/nagios/plugins/check_univention_joinstatus_suidwrapper
Danke für die Info :slight_smile:
LG
Franz
Mastodon
