VPN connection for a remote UCS host
Hi UCS
I have been building a UCS infrastructure alongside an old AD that I soon hope to phase out. All UCS hosts are on 5.0-9. I would like to add a remote host as a backup server and mail host. I managed to get a UCS host up and running on Hetzner, but I am having trouble to enable a connection to my internal network. Because of limitations on the Hetzner cloud networking, I would need a VPN connection on the UCS VM itself. I don’t seem to be able to install wireguard or openVPN, or install or build sshuttle. Is there any kind of VPN client or site-to-site VPN solution available on the UCS host itself?
Thanks in advance,
Gizzmonious
available in the app center of ucs - site to site seems not to be free to use but pricing seems moderate
rg
Christian
@externa1 Thanks! will look into that.
Is it possible to install apps before the initial domain setup wizard is completed? I would need the VPN connected to join the existing UCS domain.
Looking into UCS in Docker, with a wireguard tunnel on the host…
Hi
look here, I made it with opnsense
Best Ben
