Virtual Machine cannot connect - the network does not work -Univention SuiteCRM
I have this problem. The network was not loading
The network services does not load
So the get in into the console and found that:
[FAILED] Failed to start Raise network interfaces.
 See 'systemctl status networking.service' for details
I did the command and the service was not load:
Solved by changing file /etc/network/interfaces doing:
vi /etc/network/interfaces
auto lo
to:
auto lo
iface lo inet loopback
allow-hotplug eth0
iface eth0 inet dhcp
then reboot and everything was fine again
A network card is missing from your /etc/network/interfaces. Was the problem right after the installation or did it work before?
During the UCS installation the configuration of the network is done. Was a network card shown here for configuration?
Hello Pixel,
The problem was after the installation. It works fine for months but for some reason (that i don’t know) the VPS lost connections
