nach dem hinzufügen eines neuen Computer kommt nach dem erstellen des virtuellen Laufwerks (Festplatten und CD-Rom) immer folgender Fehler:
Interner Server-Fehler.
Fehlernachricht des Servers:
Fehler beim Definieren der Domäne "yavdr": invalid argument: could not find capabilities for arch=x86_64 domaintype=kvm
Wo kann ich da ansetzen? Welche log Dateien muss ich da anschauen?
virtual-machine-manager-daemon-errors.log:
=== 21066 === Sun, 23 Apr 2017 19:37:43 +0200 ===
=== 1343 === Sun, 23 Apr 2017 19:41:50 +0200 ===
virtual-machine-manager-daemon.log
2017-04-23 19:37:44,711 - uvmmd.node - WARNING - 'qemu://s1.semsa.de/system' broken? next check in 0:00:30.000. unable to connect to server at 's1.semsa.de:16514': Connection refused
2017-04-23 19:38:14,717 - uvmmd.node - WARNING - 'qemu://s1.semsa.de/system' broken? next check in 0:01:00.000. unable to connect to server at 's1.semsa.de:16514': Connection refused
2017-04-23 19:42:35,842 - uvmmd.node - INFO - timer_callback(qemu://s1.semsa.de/system) start
2017-04-23 19:42:36,143 - uvmmd.node - INFO - Connected to 'qemu://s1.semsa.de/system'
2017-04-23 19:47:16,293 - uvmmd.storage - WARNING - Reusing existing volume "/var/lib/libvirt/images/vdr-0.qcow2" for domain "vdr"
2017-04-23 19:47:16,315 - uvmmd.node - ERROR - invalid argument: could not find capabilities for arch=x86_64 domaintype=kvm
2017-04-23 19:47:16,316 - uvmmd.unix - WARNING - [69] Error doing command "DOMAIN_DEFINE": Error defining domain "vdr": invalid argument: could not find capabilities for arch=x86_64 domaintype=kvm
2017-04-23 19:48:04,192 - uvmmd.storage - WARNING - Reusing existing volume "/var/lib/libvirt/images/vdr-0.qcow2" for domain "vdr.s1.semsa.de"
2017-04-23 19:48:04,192 - uvmmd.node - ERROR - invalid argument: could not find capabilities for arch=x86_64 domaintype=kvm
2017-04-23 19:48:04,193 - uvmmd.unix - WARNING - [89] Error doing command "DOMAIN_DEFINE": Error defining domain "vdr.s1.semsa.de": invalid argument: could not find capabilities for arch=x86_64 domai$
2017-04-23 19:49:42,988 - uvmmd.storage - WARNING - Reusing existing volume "/var/lib/libvirt/images/vdr-0.qcow2" for domain "vdr"
2017-04-23 19:49:42,989 - uvmmd.node - ERROR - invalid argument: could not find capabilities for arch=x86_64 domaintype=kvm
2017-04-23 19:49:42,989 - uvmmd.unix - WARNING - [145] Error doing command "DOMAIN_DEFINE": Error defining domain "vdr": invalid argument: could not find capabilities for arch=x86_64 domaintype=kvm
2017-04-23 19:55:13,836 - uvmmd.storage - INFO - create_storage_volume: libvirt error (50): Storage volume not found: no storage vol with matching path '/var/lib/libvirt/images/yavdr-0.qcow2'
2017-04-23 19:55:13,838 - uvmmd.storage - INFO - create_storage_volume: libvirt error (50): Storage volume not found: no storage vol with matching name 'yavdr-0.qcow2'
2017-04-23 19:55:13,962 - uvmmd.storage - INFO - New disk "/var/lib/libvirt/images/yavdr-0.qcow2" for "yavdr"(None) defined.
2017-04-23 19:55:13,963 - uvmmd.node - ERROR - invalid argument: could not find capabilities for arch=x86_64 domaintype=kvm
2017-04-23 19:55:13,963 - uvmmd.unix - WARNING - [304] Error doing command "DOMAIN_DEFINE": Error defining domain "yavdr": invalid argument: could not find capabilities for arch=x86_64 domaintype=kvm
2017-04-23 20:03:35,102 - uvmmd.storage - WARNING - Reusing existing volume "/var/lib/libvirt/images/yavdr-0.qcow2" for domain "yavdr"
2017-04-23 20:03:35,102 - uvmmd.node - ERROR - invalid argument: could not find capabilities for arch=x86_64 domaintype=kvm
2017-04-23 20:03:35,102 - uvmmd.unix - WARNING - [653] Error doing command "DOMAIN_DEFINE": Error defining domain "yavdr": invalid argument: could not find capabilities for arch=x86_64 domaintype=kvm
2017-04-23 20:11:16,966 - uvmmd.storage - WARNING - Reusing existing volume "/var/lib/libvirt/images/yavdr-0.qcow2" for domain "yavdr"
2017-04-23 20:11:16,967 - uvmmd.node - ERROR - invalid argument: could not find capabilities for arch=x86_64 domaintype=kvm
2017-04-23 20:11:16,967 - uvmmd.unix - WARNING - [980] Error doing command "DOMAIN_DEFINE": Error defining domain "yavdr": invalid argument: could not find capabilities for arch=x86_64 domaintype=kvm
MfG,
Stefan
Leider war ich vorhin nicht deutlich genug, denn es braucht beide Module:
