/usr/share/univention-lib/join.sh missing
Hello community,
I tried to update to UCS 5.0 recently, and my webinterface doesn’t work now.
The server I am doing this on is a testing VM, cloned from our main UCS server.
The main server doesn’t have the file either, but runs smoothly for some reason.
I noticed the error when I wanted to open the web interface, it didn’t work and I decided to reinstall the administration packages:
# apt install univention-management-console-frontend univention-management-console
/var/lib/dpkg/info/univention-management-console-module-ipchange.postinst: 6: .: Can't open /usr/share/univention-lib/join.sh
/var/lib/dpkg/info/univention-management-console-module-ucr.postinst: 6: .: Can't open /usr/share/univention-lib/join.sh
Errors occured while updating:
Any hints or help appreciated.
Hi. I have the same error
