Hi there!
Could I install current stable Univention Corporate server on Debian 10 by adding its repos to sources.list ?
Hi there!
No, while UCS 4.4 is way closer to Debian 9 compared to previous earlier versions where the divergence was quite a bit heavier, there are still a lot of differences between vanilla Debian and UCS. UCS 5 targets Debian 10 and is still under development.
The situation is not compareable to i.e. Proxmox where you can actually do that (and where this is actually documented).
@msi Thanks for a quick reply, I see.
Is there any possibility to use UCS5 beta for testing or personal purposes?
Can I build UCS environment from the ground up (sources or something like that)?
Not that I know of. There is no full 5.0 branch yet on Github either, there are developer branches (See https://github.com/univention/univention-corporate-server)
You might be able to build UCS 4.4-5 from the ground up but it’s quite difficult since the repository contains the modifications Univention puts around and on top of vanilla Debian 9 and is not a full clone of Debian 9 repositories.
Thank you, appreciate your feedback.
Have a nice weekend!
