I found some notes from a collegue of my former company. Though I havent tested them by myself I have no reason to doubt that the steps described are working at all. The documentation was written in 2019.
The original request was:
- block for 60 minutes after 3 failed ssh-logins
- optional permablock after 3 temporary blocks within 24 hours
Copy&Paste follows
univention-install fail2ban
/etc/fail2ban/jail.local (please adjust the ignoreip line)
cp /etc/fail2ban/jail.conf /etc/fail2ban/jail.local
sed -i 's/ignoreip = 127.0.0.1\/8/ignoreip = 127.0.0.1\/8 192.168.0.0\/24 78.47.199.152/' /etc/fail2ban/jail.local
sed -i 's/bantime = 600/bantime = 86400/' /etc/fail2ban/jail.local
sed -i 's/findtime = 3600/findtime = 3600/' /etc/fail2ban/jail.local
sed -i 's/maxretry = 5/maxretry = 3/' /etc/fail2ban/jail.local
sed -i 's/backend = auto/backend = systemd/' /etc/fail2ban/jail.local
sed -i '/^\[sshd\]/,/^:space:*$/ s/^:space:*$/enabled = true/' /etc/fail2ban/jail.local
cat <<EOF >> /etc/fail2ban/jail.local
[repeatoffender]
enabled = true
backend = auto
filter = repeatoffender
action = repeatoffender[name=repeatoffender]
logpath = /var/log/fail2ban*
maxretry = 10
findtime = 31536000
bantime = -1
EOF
/etc/logrotate.d/fail2ban
sed -i 's/^\([^#]\)/#\1/g' /etc/logrotate.d/fail2ban
cat <<EOF >> /etc/logrotate.d/fail2ban
/var/log/fail2ban.log {
missingok
notifempty
monthly
rotate 13
create 0600 root root
postrotate
/usr/bin/fail2ban-client set logtarget /var/log/fail2ban.log 2> /dev/null || true
endscript
EOF
/etc/fail2ban/filter.d/repeatoffender.conf
cat <<EOF >> /etc/fail2ban/filter.d/repeatoffender.conf
[Definition]
_jailname = repeatoffender
failregex = fail2ban.actions\s+\[(?:.*)\]:\s+NOTICE\s+\[(?:.*)\]\s+Ban\s+<HOST>
ignoreregex = fail2ban.filter\s+\[(?:.*)\]:\s+WARNING\s+\[%(_jailname)s\]\s+Ban\s+<HOST>
EOF
/etc/fail2ban/action.d/repeatoffender.conf
cat <<\EOF >> /etc/fail2ban/action.d/repeatoffender.conf
[INCLUDES]
before = iptables-common.conf
[Definition]
# Option: actionstart
# Notes.: command executed once at the start of Fail2Ban.
# Values: CMD
actionstart = iptables -N fail2ban-<name>
iptables -A fail2ban-<name> -j RETURN
iptables -I <chain> -p <protocol> -j fail2ban-<name>
# Establish chain and blocks for saved IPs
iptables -N fail2ban-ip-blocklist
iptables -A fail2ban-ip-blocklist -j RETURN
iptables -I <chain> -p <protocol> -j fail2ban-ip-blocklist
cat /etc/fail2ban/ip.blocklist.<name> |grep -v ^\s*#|awk '{print $1}' | while read IP; do iptables -I fail2ban-ip-blocklist 1 -s $IP -j REJECT --reject-with icmp-port-unreachable; done
# Option: actionstop
# Notes.: command executed once at the end of Fail2Ban
# Values: CMD
actionstop = iptables -D <chain> -p <protocol> -j fail2ban-<name>
iptables -F fail2ban-<name>
iptables -X fail2ban-<name>
# Remove chain and blocks for saved IPs to prevent duplicates on service restart
iptables -D <chain> -p <protocol> -j fail2ban-ip-blocklist
iptables -F fail2ban-ip-blocklist
iptables -X fail2ban-ip-blocklist
# Option: actioncheck
# Notes.: command executed once before each actionban command
# Values: CMD
actioncheck = iptables -n -L <chain> | grep -q 'fail2ban-<name>[ \t]'
# Option: actionban
# Notes.: command executed when banning an IP. Take care that the
# command is executed with Fail2Ban user rights.
# Tags: See jail.conf(5) man page
# Values: CMD
actionban = VERIFY="<ip>*"
ADD="<ip> # fail2ban/$( date '+%%Y-%%m-%%d %%T' ): Perma-Banned"
FILE=/etc/fail2ban/ip.blocklist.<name>
grep -q "$VERIFY" "$FILE" || iptables -I fail2ban-<name> 1 -s <ip> -j DROP
grep -q "$VERIFY" "$FILE" || echo "$ADD" >> "$FILE"
# Option: actionunban
# Notes.: command executed when unbanning an IP. Take care that the
# Values: CMD
actionunban = # Do nothing because their IP is in the blocklist file
# To manually unban from the ip blocklist file run this command:
# Be warned that if the ip is in log rotated files it must be whitelisted
# sed -i '/^<ip>/d' /etc/fail2ban/ip.blocklist.repeatoffender
[Init]
# Default name of the chain
name = default
# Option: protocol
# Notes.: internally used by config reader for interpolations.
# Values: [ tcp | udp | icmp | all ] Default: tcp
protocol = tcp
# Option: chain
# Notes specifies the iptables chain to which the fail2ban rules should be
# added
# Values: STRING Default: INPUT
chain = INPUT
EOF
Regarding IPv6 support refer to fail2ban/ChangeLog at master · fail2ban/fail2ban · GitHub (fail2ban 0.10 is available in Debian Buster and therefor with UCS 5)
hth and have fun
