Users Tab wont load after Lets Encrypt install
i had a clean UCS install where i could add users. Then i installed lets encrypt plugin - since that one i have the follow behaiviour:
users
nothing anymore is happing until the popup for logout-tab comes up…
all updates are installed (did also throug apt update and upgrade,…)
Additonal informatiosn_:
Server
ucs.sys-fn.local
UCS-Version
4.4-0 errata59 (Blumenthal)
UMC-Version
11.0.4-9A~4.4.0.201903141619
Gültigkeitsdatum des SSL-Wurzel-Zertifikats
24. April 2024 um
Gültigkeitsdatum des SSL-Rechner-Zertifikats
24. April 2024 um
does anyone have an idea?
dont know why, but did fix itself over the night,…
