Hello Community.
I have a general questen. But, at first I want do describe my setup and plans.
I have a Active Directory Server to wich I’ve joined Univention. Univention has read the accounts from Active Directory. Additionally I run a Zrafa Mailserver which should be replaced by Kopano on the mentioned Univention system. In the future I want to completly replace Active Directory as well.
Zarafa does not use the same user basis as Active Directory,
Which leads me directly to my question: Can I have an alias for active directory account which Kopano has read? I’d like to use this as the login for Kopano.
So… Basically the Username from AD/Univention should be in sync with the current Windows logins and the alias should be in sync with the current Zarafa usernames.
Can I simply set an E-Mail address like user.name@domain.tld and tell Kopano to use this for auth?
Thank you in advance.
Best regards,
Martin.
