Just installed SuiteCRM from Univention App catalog (ESX OVA Image)
UCS version is 4.3-2 errata234
SuiteCRM Version 7.10.7
Sugar Version 6.5.25 (Build 344)
Enabled checkbox for UCS Administrator user for SuiteCRM (checked Administrator checkbox also), but when I logon to SuiteCRM - reviewing user Administrator profile the user type is regular user, hence no access to admin portal. Attached details.
Uncheck the Admin checkbox in Univention management, wait 30 seconds and check it again
Please send us the console output.
You can quit the tail command with Ctrl-C and then enter
exit
to exit the univention-app command
Workaround
Please enter the following commands on a linux command line as root
just to report, work around worked OK. User with Admin role now. Bellow info from listener log
Although I did not see anything get logged while making changes on users
Do I need to enable some kind of debug option??
root@crm2018:~# univention-app shell digitec-suitecrm
root@digit-53905963:/# tail -f /var/log/univention/listener.log
11.09.18 18:32:41.105 LISTENER ( PROCESS ) : updating 'cn=Is_Active_SuiteCRM,cn=DIGITEC SuiteCRM Attributes,cn=custom attributes,cn=univention,dc=aysco,dc=ms' command a
11.09.18 18:32:41.108 LISTENER ( PROCESS ) : updating 'cn=Is_Admin_SuiteCRM,cn=DIGITEC SuiteCRM Attributes,cn=custom attributes,cn=univention,dc=aysco,dc=ms' command a
11.09.18 18:32:41.120 LISTENER ( PROCESS ) : updating 'cn=EmployeeStatus_SuiteCRM,cn=DIGITEC SuiteCRM Attributes,cn=custom attributes,cn=univention,dc=aysco,dc=ms' command a
11.09.18 18:32:41.126 LISTENER ( PROCESS ) : updating 'cn=Roles_SuiteCRM,cn=DIGITEC SuiteCRM Attributes,cn=custom attributes,cn=univention,dc=aysco,dc=ms' command a
11.09.18 18:33:05.940 LISTENER ( PROCESS ) : updating 'cn=crm2018,cn=dc,cn=computers,dc=aysco,dc=ms' command m
11.09.18 18:34:23.555 LISTENER ( WARN ) : received signal 15
11.09.18 18:34:29.587 DEBUG_INIT
11.09.18 18:34:31.332 MODULE ( WARN ) : Ignoring import error: No module named dns.resolver
11.09.18 18:34:31.724 LISTENER ( WARN ) : initializing module suitecrm-suitecrm
11.09.18 18:34:32.740 LISTENER ( WARN ) : finished initializing module suitecrm-suitecrm with rv=0
^C
Hello - we are experiencing the same issue, and we installed from the OVA as well, same version and build. we ran the commands but no change. The admin option is not shown.
