Uppdate to 4.4-3 errata413 breaks on 97univention-s4-connector.inst
RUNNING 97univention-s4-connector.inst return EXITCODE=1
This is the join.log
Thu Dec 19 17:37:34 CET 2019
univention-join-hooks: looking for hook type "join/pre-joinscripts" on ucs-fs.sunhut.local
Found hooks:
2019-12-19 17:37:35.195871970+01:00 (in joinscript_init)
19.12.19 17:37:35.582  DEBUG_INIT
UNIVENTION_DEBUG_BEGIN  : uldap.__open host=ucs-fs.sunhut.local port=7389 base=dc=sunhut,dc=local
UNIVENTION_DEBUG_END    : uldap.__open host=ucs-fs.sunhut.local port=7389 base=dc=sunhut,dc=local
Not updating connector/s4/ldap/host
Not updating connector/s4/ldap/base
Not updating connector/s4/ldap/ssl
Not updating connector/s4/mapping/group/language
Not updating connector/s4/ldap/protocol
Not updating connector/s4/ldap/socket
Object exists: cn=gPLink,cn=custom attributes,cn=univention,dc=sunhut,dc=local
Object exists: cn=WMIPolicy,cn=System,dc=sunhut,dc=local
Object exists: cn=SOM,cn=WMIPolicy,cn=System,dc=sunhut,dc=local
Object exists: cn=udm_syntax,cn=univention,dc=sunhut,dc=local
INFO: No change of core data of object s4_connector.
No modification: cn=s4_connector,cn=udm_syntax,cn=univention,dc=sunhut,dc=local
Waiting for activation of the extension object s4_connector: .........................................................ERROR: Master did not mark the extension object active within 180 seconds.
ERROR
ucs_registerLDAPExtension: registraton of /usr/lib/python2.7/dist-packages/univention/admin/syntax.d/s4_connector.py failed.
Object exists: cn=ldapschema,cn=univention,dc=sunhut,dc=local
INFO: No change of core data of object msgpo.
INFO: No change of core data of object mswmi.
Object exists: cn=udm_module,cn=univention,dc=sunhut,dc=local
INFO: No change of core data of object container/msgpo.
No modification: cn=msgpo,cn=ldapschema,cn=univention,dc=sunhut,dc=local
No modification: cn=mswmi,cn=ldapschema,cn=univention,dc=sunhut,dc=local
No modification: cn=container/msgpo,cn=udm_module,cn=univention,dc=sunhut,dc=local
Waiting for activation of the extension object msgpo: .........................................................ERROR: Master did not mark the extension object active within 180 seconds.
ERROR
ucs_registerLDAPExtension: registraton of /usr/share/univention-s4-connector/ldap/msgpo.schema failed.
EXITCODE=1
7880b0f1-f05d-481b-96cf-217582a0c647
univention-join-hooks: looking for hook type "join/post-joinscripts" on ucs-fs.sunhut.local
Found hooks:
Thu Dec 19 17:43:40 CET 2019
See here.
In case it does not work, check your replication.
Thanks!
Whole bunch of objects had to be manipulated, but the join did work.
Merry holidays!
