Hallo Leute,
kann ich das Update nicht über apt einspielen?
meine Sources List.
[code]#deb http://univention-repository.itk.homeunix.net/univention-cdrom/packages/ ./
#deb cdrom:[2.0-2]/ucs-updates/2.0-2/ /
#deb cdrom:[2.0-1]/ucs-updates/2.0-1/ /
#deb http://apt.univention.de/2.0/maintained/component/ scalix/all/
#deb http://apt.univention.de/2.0/maintained/component/ scalix/i386/
#deb http://apt.univention.de/2.0/maintained/component/ scalix/extern/
#deb-src http://apt.univention.de/2.0/maintained/component/ scalix/source/
deb http://apt.univention.de/2.1/maintained/ 2.1-0/all/
deb http://apt.univention.de/2.1/maintained/ 2.1-0/i386/
deb http://apt.univention.de/2.1/maintained/ 2.1-0/amd64/
deb http://apt.univention.de/2.1/maintained/ 2.1-0/extern/
deb http://apt.univention.de/2.1/unmaintained/ 2.1-0/all/
deb http://apt.univention.de/2.1/unmaintained/ 2.1-0/i386/
deb http://apt.univention.de/2.1/unmaintained/ 2.1-0/amd64/
deb http://apt.univention.de/2.1/unmaintained/ 2.1-0/extern/
deb-src http://apt.univention.de/2.1/unmaintained/ 2.1-0/source/[/code]
ein apt-get updae ergibt:
Ign http://apt.univention.de 2.1-0/all/ Release.gpg
Ign http://apt.univention.de 2.1-0/i386/ Release.gpg
Ign http://apt.univention.de 2.1-0/amd64/ Release.gpg
Ign http://apt.univention.de 2.1-0/extern/ Release.gpg
Ign http://apt.univention.de 2.1-0/source/ Release.gpg
Ign http://apt.univention.de 2.1-0/all/ Packages/DiffIndex
Ign http://apt.univention.de 2.1-0/i386/ Packages
Ign http://apt.univention.de 2.1-0/amd64/ Packages
Ign http://apt.univention.de 2.1-0/extern/ Packages/DiffIndex
Ign http://apt.univention.de 2.1-0/i386/ Packages/DiffIndex
Ign http://apt.univention.de 2.1-0/amd64/ Packages/DiffIndex
Ign http://apt.univention.de 2.1-0/source/ Sources/DiffIndex
Hole:1 http://apt.univention.de 2.1-0/i386/ Packages [123kB]
Hole:2 http://apt.univention.de 2.1-0/amd64/ Packages [125kB]
99% [1 Packages gzip 0] [Warte auf Kopfzeilen (header)]
gzip: stdin: not in gzip format
Fehl http://apt.univention.de 2.1-0/i386/ Packages
Unterprozess gzip ist mit einem Fehlercode zurückgekehrt (1)
99% [2 Packages gzip 0] [Warte auf Kopfzeilen (header)]
Fehl http://apt.univention.de 2.1-0/amd64/ Packages
OK http://apt.univention.de 2.1-0/all/ Packages
OK http://apt.univention.de 2.1-0/extern/ Packages
OK http://apt.univention.de 2.1-0/i386/ Packages
OK http://apt.univention.de 2.1-0/amd64/ Packages
OK http://apt.univention.de 2.1-0/source/ Sources
Es wurden 2B in 2s geholt (1B/s)
Konnte http://apt.univention.de/2.1/maintained/2.1-0/i386/Packages.gz nicht holen Unterprozess gzip ist mit einem Fehlercode zurückgekehrt (1)
Konnte http://apt.univention.de/2.1/maintained/2.1-0/amd64/Packages.gz nicht holen Unterprozess gzip ist mit einem Fehlercode zurückgekehrt (1)
Paketlisten werden gelesen... Fertig
W: Kann nicht auf die Liste http://apt.univention.de 2.1-0/i386/ Packages (/var/lib/apt/lists/apt.univention.de_2.1_maintained_2.1-0_i386_Packages) der Quellpakete zugreifen. - stat (2 Datei oder Verzeichnis nicht gefunden)
W: Kann nicht auf die Liste http://apt.univention.de 2.1-0/amd64/ Packages (/var/lib/apt/lists/apt.univention.de_2.1_maintained_2.1-0_amd64_Packages) der Quellpakete zugreifen. - stat (2 Datei oder Verzeichnis nicht gefunden)
W: Probieren Sie âapt-get updateâ, um diese Probleme zu korrigieren.
E: Einige Indexdateien konnten nicht heruntergeladen werden, sie wurden ignoriert oder alte an ihrer Stelle benutzt.
Ist da noch ein Fehler?
Gruß
Schmide
