Upgraded Backup Directory Node Join fail after Upgrade
I just upgraded a Backup Directory Node to 5.2.2
After the upgrade, several Join Scripts give me a headache:
20univention-join
30univention-appcenter
30univention-monitoring-client
33univention-portal
49univention-keycloak-client
All other scripts seem to be okay.
Unfortunately, the join script is of no help:
Enter Primary Directory Node Account : Administrator
Enter Primary Directory Node Password:
Search Primary Directory Node:                             done
Check Primary Directory Node:                              done
Stop S4-Connector:                                         done
Stop LDAP Server:                                          done
Stop Samba Server:                                         done
Search ldap/base                                           done
Start LDAP Server:                                         done
Search LDAP binddn                                         done
Running pre-join hook(s):
* Join failed!                                                           *
* Contact your system administrator                                      *
* Message:  Please visit https://help.univention.com/t/8842 for common problems during the join and how to fix them -- join/pre-join failed, see /var/log/univention/join.log
It looks like the pre-join hooks do not work. I have gone through Requirements for a successful join into the UCS domain, those tests all work.
Any help would be greatly appreciated.
Please post the full join log.
Hi boospy, thanks for your quick reply.
I decided to roll back to a previous backup, make sure that everything is working before I start again to try to upgrade.
