I have a working 4.4-1 server with Kopano 8.7.1. I keep up with all core and application errata updates when they are available. Today, I ran the upgrade process to 4.4-2. Now, Kopano /var/log/mail.log shows mail status=deferred, connection refused (127.0.0.1)
It appears that all of the Kopano services are running. I have tried power cycling the server. The behavior is the same.
I found that clamd and amavis-new were no longer installed and running. I used univention-install to reinstall them and restarted the server. Checking with ps -A, they both now seem to be running.
But, here is the error messages I am receiving in /etc/log/mail.log:
Sep 25 22:04:36 vap-mail postfix/error[16655]: 80F5216853B1: to=mmazur@vapsteel.com, relay=none, delay=21422, delays=21422/0.07/0/0.05, dsn=4.4.1, status=deferred (delivery temporarily suspended: connect to 127.0.0.1[127.0.0.1]:10024: Connection refused)
Sep 25 22:04:36 vap-mail postfix/error[16656]: C095C16853B4: to=root@vap-mail.vapsteel.com, orig_to=, relay=none, delay=21857, delays=21857/0.07/0/0.08, dsn=4.4.1, status=deferred (delivery temporarily suspended: connect to 127.0.0.1[127.0.0.1]:10024: Connection refused)
Sep 25 22:04:36 vap-mail postfix/error[16658]: D1E921680182: to=root@vap-mail.vapsteel.com, orig_to=, relay=none, delay=21857, delays=21857/0.08/0/0.07, dsn=4.4.1, status=deferred (delivery temporarily suspended: connect to 127.0.0.1[127.0.0.1]:10024: Connection refused)
Update: After reinstalling the clam and amavis applications, the Kopano system began processing mail. There was a delay of 20-30 minutes between the installation and activation of the amavis and the start of mail processing.
All things seem to be working now.
I don’t know why the 4.4-2 update would have broken these two applications. I need to dig further to see if anything else was affected.
