Upgrade to UCS 5 fail
OK i have made that
ucs_portal_remove_reinstall_1
ucs_portal_remove_reinstall_2
ucs_portal_remove_reinstall_3
I uninstalled the portal and reinstalled it.
Didn’t do anything either. At least now I see the message that did not come before.
The PORTAL does not work
https:///univention/portal/
The Univention Management Console still goes
https:///univention/umc/
Do you have any recommendation what I can do?
Thanks a lot lg Stoneucs_domainjoin
ucs_portal_remove_reinstall_4
It looks like a can of worms has been opened. I hope that you had backed your system up prior to the UCSv5 upgrade and can restore it or it is feasible to setup a new instance of UCSv5 from scratch and move the data over. This is what I personally would be seriously considering at this point. Thank you for sharing the screenshots. German is a problem for me, unfortunately. I’m sorry and good luck.
