Upgrade to UCS 4.4-2 of an memberserver: permissionDenied
this release seems to be a little bit buggy. I’ve observed this messages in the log:
Checking for package updates:                          Removing localhost from LDAP object
Registering UCR for samba-memberserver
Marking samba-memberserver=4.7 as installed
Adding localhost to LDAP object
  File "/usr/lib/python2.7/dist-packages/univention/appcenter/actions/__init__.py", line 226, in call_with_namespace
    result = self.main(namespace)
  File "/usr/lib/python2.7/dist-packages/univention/appcenter/actions/register.py", line 86, in main
    self._register_app_for_apps(apps, args)
  File "/usr/lib/python2.7/dist-packages/univention/appcenter/actions/register.py", line 414, in _register_app_for_apps
    updates.update(self._register_app(app, args, lo, pos, delay=True))
  File "/usr/lib/python2.7/dist-packages/univention/appcenter/actions/register.py", line 436, in _register_app
    ldap_object.add_localhost()
  File "/usr/lib/python2.7/dist-packages/univention/appcenter/udm.py", line 245, in add_localhost
    self._udm_obj.modify()
  File "/usr/lib/pymodules/python2.7/univention/admin/handlers/__init__.py", line 650, in modify
    dn = self._modify(modify_childs, ignore_license=ignore_license, response=response)
  File "/usr/lib/pymodules/python2.7/univention/admin/handlers/__init__.py", line 1327, in _modify
    self.dn = self.lo.modify(self.dn, ml, ignore_license=ignore_license, serverctrls=serverctrls, response=response)
  File "/usr/lib/pymodules/python2.7/univention/admin/uldap.py", line 897, in modify
    raise univention.admin.uexceptions.permissionDenied
permissionDenied
  File "/usr/bin/univention-app", line 91, in <module>
    main()
  File "/usr/bin/univention-app", line 78, in main
    ret = args.func(args)
 none
Checking for app updates:                               none
Checking for release updates:                           none
Best,
SirTux
EDIT: The app samba-memberserver isn’t shown in the AppCenter now.
Seems that this issue occurs only if the upgrade is not started via UMC.
Can you clarify if the update failed, or is that traceback printed in the updater.log but the update finished? If it finished, do you currently experience issues on that memberserver?
The updates finished but the app samba-memberserver wasn’t marked as installed afterwards. I get the same traceback if I run
univention-app register samba-memberserver
can you give the DN of said memberserver? Is it in cn=memberserver,cn=computers,$ldap_base?
No it’s in a container in cn=memberserver,cn=computers,$ldap_base. So the DN is cn=hostname,cn=subcontainer,cn=memberserver,cn=computers,$ldap_base.
Yes. This is a bug in UCS (and has little to do with 4.4-2 specifically).
In fact, I wonder how you were able to install these Apps in the first place. You may have moved the memberserver at some point? Or you installed these Apps not via the App Center but with univention-install (only works for Apps like samba-memberserver).
Here is the bug: https://forge.univention.org/bugzilla/show_bug.cgi?id=46303
It is an issue with our ACLs.
Ok that makes sense. Yes, if I remember correctly I’ve moved the server object after installing Samba.
By the way, I’m not an expert in LDAP ACLs, but that shouldn’t be difficult to fix, should be?
