Upgrade-Problem texlive
[code]Setting up texlive-latex-base (2007.dfsg.1-5.8.200909141134) …
Running mktexlsr. This may take some time… done.
Running updmap-sys. This may take some time… done.
Building format(s) --all --cnffile /etc/texmf/fmt.d/10texlive-latex-base.cnf.
fmtutil-sys failed. Output has been stored in
/tmp/fmtutil.EycaGXyk
Please include this file if you report a bug.
dpkg: error processing texlive-latex-base (–configure):
subprocess post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of texlive-latex-recommended:
texlive-latex-recommended depends on texlive-latex-base (>= 2007-11); however:
Package texlive-latex-base is not configured yet.
dpkg: error processing texlive-latex-recommended (–configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of texlive:
texlive depends on texlive-latex-recommended (>= 2007-11); however:
Package texlive-latex-recommended is not configured yet.
texlive depends on texlive-latex-base (>= 2007-11); however:
dpkg: error processing texlive (–configure):
dpkg: dependency problems prevent configuration of tetex-bin:
tetex-bin depends on texlive (>= 2007-11); however:
Package texlive is not configured yet.
dpkg: error processing tetex-bin (–configure):
Errors were encountered while processing:
texlive-latex-base
texlive
tetex-bin
Reading package lists… Done
Building dependency tree
Reading state information… Done[/code]
auf welchem Versionsstand befindet sich das System momentan? Generell sollten Sie beim Aktualisieren älterer UCS-Systeme alle folgenden Release-Notes sowie Hinweise zu älteren Versionen aus unserem Forum beachten.
Zum Beispiel: Aktualisierte Installations-Images für UCS 2.2 und Update von UCS 2.2 auf 2.x schlägt fehl (texlive-base_2007).
Mit freundlichen Grüßen,
Tim Petersen
