Hi, on our UCS (4.4-6 errata750) is OwnCloud 10.3.2-1 running.
Now i tried to upgrade to 10.4.1 but it failed:
32716 docker.configure.container.9e58 20-09-26 15:20:14 [ DEBUG]: Using container.9e58 for container 9e583ca6ad074f67428a512fe4146d6586823eb309bf382a8db0559e3868d8e4
32716 docker.configure.container.9e58 20-09-26 15:20:14 [ DEBUG]: Calling docker exec -u root 9e583ca6ad074f67428a512fe4146d6586823eb309bf382a8db0559e3868d8e4 which ucr
32716 actions.configure 20-09-26 15:20:15 [ WARNING]: ucr cannot be found, falling back to changing the database file directly
32716 actions.configure.progress 20-09-26 15:20:15 [ DEBUG]: 100
32716 actions.upgrade.progress 20-09-26 15:20:15 [ DEBUG]: 50
32716 actions.upgrade 20-09-26 15:20:15 [ INFO]: Executing interface restore_data_before_setup for owncloud
32716 actions.upgrade 20-09-26 15:20:15 [ INFO]: No interface defined
32716 actions.upgrade 20-09-26 15:20:15 [ INFO]: Executing interface setup for owncloud
32716 actions.upgrade 20-09-26 15:20:15 [ INFO]: Copying App Center’s setup to container’s /usr/share/univention-docker-container-mode/setup_custom
32716 actions.upgrade.container.9e58 20-09-26 15:20:15 [ DEBUG]: Using container.9e58 for container 9e583ca6ad074f67428a512fe4146d6586823eb309bf382a8db0559e3868d8e4
32716 actions.upgrade.container.9e58 20-09-26 15:20:15 [ DEBUG]: Calling docker exec -u root 9e583ca6ad074f67428a512fe4146d6586823eb309bf382a8db0559e3868d8e4 /usr/share/univention-docker-container-mode/setup_custom --username Administrator --app owncloud --error-file /var/univention/tmp/tmp7zKZ0U --password-file /var/univention/tmp/tmpOkAvsu --app-version 10.4.1
32716 actions.upgrade.container.9e58 20-09-26 15:20:15 [ INFO]: [02.DOCKER_SETUP] Enable user_ldap app
32716 actions.upgrade.container.9e58 20-09-26 15:20:16 [ INFO]: .
32716 actions.upgrade.container.9e58 20-09-26 15:20:16 [ INFO]: [02.DOCKER_SETUP] user_ldap enabled successfully! after 1 tries
32716 actions.upgrade.container.9e58 20-09-26 15:20:16 [ INFO]: [02.DOCKER_SETUP] Waiting for LDAP app testing…
32716 packages 20-09-26 15:20:16 [ DEBUG]: Releasing LOCK
32716 actions.upgrade 20-09-26 15:20:16 [CRITICAL]: Setup script failed!
32716 actions.upgrade 20-09-26 15:20:16 [ WARNING]: Aborting…
32716 utils 20-09-26 15:20:16 [ DEBUG]: send_information: action=upgrade app=owncloud value={‘code’: 137, ‘stderr’: [’[02.DOCKER_SETUP] Enable user_ldap app’, ‘.’, ‘[02.DOCKER_SETUP] user_ldap enabled successfully! after 1 tries’, ‘[02.DOCKER_SETUP] Waiting for LDAP app testing…’, ‘.’]} status=416
32716 utils 20-09-26 15:20:16 [ DEBUG]: tracking information: {‘status’: 416, ‘uuid’: ‘45a79ff3-6594-4ace-917a-258e59dc5442’, ‘app’: u’owncloud’, ‘value’: {‘code’: 137, ‘stderr’: [’[02.DOCKER_SETUP] Enable user_ldap app’, ‘.’, ‘[02.DOCKER_SETUP] user_ldap enabled successfully! after 1 tries’, ‘[02.DOCKER_SETUP] Waiting for LDAP app testing…’, ‘.’]}, ‘version’: u’10.4.1’, ‘role’: ‘domaincontroller_master’, ‘action’: ‘upgrade’, ‘system-uuid’: ‘43b3668b-d026-4589-8ff1-cd1215275b25’}
If i uninstall the OC and install the new version, does all data and users remain and what about the configuration ?
Thx Holger
