Upgrade did not migrate the group and it's misisng in URL
Hello everyone! I recently upgraded Rocket chat several versions until reaching the latest 6.5.2. The issue I have after the upgrade is that many URL links and shortcuts seem to be missing /rocketchat after the FQDN and displays a 404. It appears that the word ‘group’ is in its place.
For example:
fqdn.com - Diese Website steht zum Verkauf! - Informationen zum Thema fqdn. displays a 404 until I replace /group with /rocketchat
fqdn.com - Diese Website steht zum Verkauf! - Informationen zum Thema fqdn. works fine.
In some URLs it’s missing completely:
/admin/settings I have to append /rocketchat/admin/settings for it to work.
Is there a place to go to fix this?
I found this about the issue. It looks like in 4.0 they discontinued support for sub folders but then continued to support it after some users complained.
I am in 6.5.2 so support is there again.
It looks like I need to edit the following:
To run in a subfolder you should pass the environment variable ROOT_URL to the process. For example:
ROOT_URL=https://your.domain.com/chat/ node main.js
I could use some advice before tinkering with this… where do I even find the ROOT url to edit? I am guessing this is in the RocketChat container and not in the Univention server.
