Im der Datei /var/log/univention/updater.log des DC Masters taucht nach
univention-repository-update net
immer
[code]**** Starting univention-updater with parameter=[’/usr/sbin/univention-updater’, ‘net’, ‘–silent’, ‘–check’]
—>DBG:update_available(mode=net, cdrom_mount_point=/cdrom, iso=None)
Checking network repository
System is up to date
auf. Das Verzeichnis existiert aber auf dem Server.
ucr search repository
gibt aus:
[code]directory/manager/web/modules/policies/repositoryserver/additional: apt.univention.de
directory/manager/web/modules/policies/repositoryserver/search/default: name
directory/manager/web/modules/policies/repositorysync/search/default: name
local/repository: yes
Enable/Disable the local repository
online/repository/clean:
Create script to delete obsolete packages from the local repository [no]
repository/mirror/architectures:
List of architectures copied to the local repository, space separated
repository/mirror/basepath: /var/lib/univention-repository
Directory prefix of the local repository [/var/lib/univention-repository]
repository/mirror/httpmethod:
HTTP methode for testing the availability of updates [HEAD]
repository/mirror/port:
TCP port number of the repository servers [80]
repository/mirror/prefix:
Update directory on the repository server [univention-repository]
repository/mirror/recreate_packages: yes
Re-create list of packages in local repository after updates, instead of copying it [yes]
repository/mirror/server: apt.univention.de
Server, from which packages are copied for the local repository [apt.univention.de]
repository/mirror/sources:
Mirror source code files to local repository
repository/mirror/threads: 10
Maximum number of parallel downloads [10]
repository/mirror/version/end: 2.4-2
Highest version in the local repository
repository/mirror/version/start: 2.3-0
Lowest version for the local repository
repository/mirror: yes
Enable/Disable mirroring packages into the local repository [yes]
repository/online/component/nitrobit/parts: unmaintained
repository/online/component/nitrobit/version: 2.2
repository/online/component/nitrobit: enabled
repository/online/component/ox/description: Open-Xchange Server
repository/online/component/ox/password: *******
repository/online/component/ox/prefix: OX6/OXSEforUCS
repository/online/component/ox/server: software.open-xchange.com
repository/online/component/ox/username: *******
repository/online/component/ox/version: current
repository/online/component/oxmobility/defaultpackage: open-xchange-meta-mobility univention-ox-usm-ox
repository/online/component/oxmobility/description: OXtender for Business Mobility
repository/online/component/oxmobility/password: *******
repository/online/component/oxmobility/prefix: OX6/OXSEforUCS
repository/online/component/oxmobility/server: software.open-xchange.com
repository/online/component/oxmobility/username: *******
repository/online/component/oxmobility/version: current
repository/online/component/oxmobility: enabled
repository/online/component/oxoutlook/defaultpackage: open-xchange-outlook-updater
repository/online/component/oxoutlook/description: OXtender for MS Outlook
repository/online/component/oxoutlook/password: *******
repository/online/component/oxoutlook/prefix: OX6/OXSEforUCS
repository/online/component/oxoutlook/server: software.open-xchange.com
repository/online/component/oxoutlook/username: ********
repository/online/component/oxoutlook/version: current
repository/online/component/oxoutlook: enabled
repository/online/component/oxseforucs/password: ********
repository/online/component/oxseforucs/server: software.open-xchange.com
repository/online/component/oxseforucs/username: ******
repository/online/component/oxseforucs/version: current
repository/online/component/oxseforucs: enabled
repository/online/hotfixes: yes
Use hotfix packages for security updates [no]
repository/online/httpmethod:
repository/online/maintained: yes
Use packages from the maintained section [yes]
repository/online/port: 80
TCP port number of the online repository servers [80]
repository/online/prefix: univention-repository
repository/online/server: ucsmaster.local
Server holding the Repository [apt.univention.de]
repository/online/sources:
Make source code files available on local host [no]
repository/online/unmaintained: no
Use packages from the unmaintained section [no]
repository/online: yes
Enable/Disable the use of the online repository servers [yes][/code]
