Upgrade 5.0 fails due to leftovers from uninstalled ox-appsuite
Hello together,
a long time ago I’ve installed ox-appsuite on my system for testing - I’ve removed it perhaps two years ago but there where leftovers that will prevent update now. I get the following message:
The system can not be updated to UCS 5.0 due to the following reasons:
python_ucr_template_compatibility:
The following UCR templates are not compatible with Python 3:
         /etc/univention/templates/files/etc/ldap/slapd.conf.d/66oxforucs.acl
minimum_ucs_version_of_all_systems_in_domain:
The following extensions are incompatible with UCS 5.0:
        cn=66oxforucs,cn=ldapacl,cn=univention,dc=domain,dc=lan: [unspecified..unspecified)
        cn=50_ox,cn=udm_syntax,cn=univention,dc=domain,dc=lan: [unspecified..unspecified)
        cn=oxAccess,cn=udm_hook,cn=univention,dc=domain,dc=lan: [unspecified..unspecified)
        cn=oxGroupHook,cn=udm_hook,cn=univention,dc=domain,dc=lan: [unspecified..unspecified)
        cn=oxUserDefaults,cn=udm_hook,cn=univention,dc=domain,dc=lan: [unspecified..unspecified)
        cn=oxmail/oxcontext,cn=udm_module,cn=univention,dc=domain,dc=lan: [unspecified..unspecified)
        cn=oxmail/oxdomain,cn=udm_module,cn=univention,dc=domain,dc=lan: [unspecified..unspecified)
        cn=oxmail/oxfetchmailmulti,cn=udm_module,cn=univention,dc=domain,dc=lan: [unspecified..unspecified)
        cn=oxmail/oxfetchmailsingle,cn=udm_module,cn=univention,dc=domain,dc=lan: [unspecified..unspecified)
        cn=oxmail/oxfolder,cn=udm_module,cn=univention,dc=domain,dc=lan: [unspecified..unspecified)
        cn=oxmail/oxlists,cn=udm_module,cn=univention,dc=domain,dc=lan: [unspecified..unspecified)
        cn=oxmail/oxmail,cn=udm_module,cn=univention,dc=domain,dc=lan: [unspecified..unspecified)
        cn=oxresources/oxresources,cn=udm_module,cn=univention,dc=domain,dc=lan: [unspecified..unspecified)
        cn=oxContextRW,cn=udm_hook,cn=univention,dc=domain,dc=lan: [unspecified..unspecified)
I have tried to move the file and ucr commit /etc/ldap/sldap.conf but while it will build a new version of sldap.conf there is an error in building it:
Failed to process Subfile /etc/univention/templates/files/etc/ldap/slapd.conf.d/66oxforucs.acl
Multifile: /etc/ldap/slapd.conf
So this is not enough.
Question is then - how should I proceed?
There are also two guacamole related entries preventing the update:
     (ox...)
        cn=guacamole,cn=udm_syntax,cn=univention,dc=domain,dc=lan: [unspecified..unspecified)
        cn=guacamole/config,cn=udm_module,cn=univention,dc=domain,dc=lan: [unspecified..unspecified)
What do they do and will guacamole on a member-server/ managed node still work?
Best,
Bernd
If you don’t need OX anymore you should purge the packages:
apt purge univention-ox-dependencies-master univention-ox-directory-integration (make sure ucr get ox/master/42/registered_ldap_acls is set to yes, otherwise don’t purge).
Then see, if purging removes the extended attributes? Otherwise they can be removed manually.
guacamole is not yet ready for UCS 5.0, I guess the vendor is working on it. Please re-check a few weeks later.
Thank you for your support on this one.
It isn’t working like this on my system, there are still leftover files.
But I don’t see a problem removing the extended attributes manually and I also have found a second corresponding .info-file for /etc/univention/templates/files/etc/ldap/slapd.conf.d/66oxforucs.acl
in /etc/univention/templates/info/ so that I don’t get that error on building sldap.conf
The ucr variable ox/master/42/registered_ldap_acls is still set to yes. Do I just leave it this way or should I remove the ox-variables?
I also still have the udm - modules ox resources and ox mail (instead of mail) / do I have to worry about these? Or will they just disappear during the update?
They disappear when the extended attributes are cleared (and a server restart).
This is the object which created the UDM module oxmail/oxmail. If this is removed, the module is not shown anymore.
You can safely unset the Variable if you remove the .info file and the template.
Hi Best,
I am not so familiar with Debian/ Linux, but I have the same problem:
cn=58univention-fetchmail-schema,cn=ldapacl,cn=univention,dc=heg,dc=int: [unspecified…unspecified)
cn=66oxforucs,cn=ldapacl,cn=univention,dc=heg,dc=int: [unspecified…unspecified)
cn=50_ox,cn=udm_syntax,cn=univention,dc=heg,dc=int: [unspecified…unspecified)
cn=oxAccess,cn=udm_hook,cn=univention,dc=heg,dc=int: [unspecified…unspecified)
cn=oxContextRW,cn=udm_hook,cn=univention,dc=heg,dc=int: [unspecified…unspecified)
cn=oxGroupHook,cn=udm_hook,cn=univention,dc=heg,dc=int: [unspecified…unspecified)
cn=oxUserDefaults,cn=udm_hook,cn=univention,dc=heg,dc=int: [unspecified…unspecified)
cn=oxmail/oxcontext,cn=udm_module,cn=univention,dc=heg,dc=int: [unspecified…unspecified)
cn=oxmail/oxdomain,cn=udm_module,cn=univention,dc=heg,dc=int: [unspecified…unspecified)
cn=oxmail/oxfetchmailmulti,cn=udm_module,cn=univention,dc=heg,dc=int: [unspecified…unspecified)
cn=oxmail/oxfetchmailsingle,cn=udm_module,cn=univention,dc=heg,dc=int: [unspecified…unspecified)
cn=oxmail/oxfolder,cn=udm_module,cn=univention,dc=heg,dc=int: [unspecified…unspecified)
cn=oxmail/oxlists,cn=udm_module,cn=univention,dc=heg,dc=int: [unspecified…unspecified)
cn=oxmail/oxmail,cn=udm_module,cn=univention,dc=heg,dc=int: [unspecified…unspecified)
cn=oxresources/oxresources,cn=udm_module,cn=univention,dc=heg,dc=int: [unspecified…unspecified)
cn=63openvpn-sitetosite,cn=ldapacl,cn=univention,dc=heg,dc=int: [unspecified…unspecified)
cn=univention-openvpn-schema,cn=udm_syntax,cn=univention,dc=heg,dc=int: [unspecified…unspecified)
cn=univention-openvpn,cn=udm_hook,cn=univention,dc=heg,dc=int: [unspecified…unspecified)
Error: Update aborted by pre-update script of release 5.0-0
How can I remove these extensions manually ?
OX was already uninstalled, so the apt purge did no more work.
Or do I have to reinstall OX to remove it with apt purge ?
Any help is appreciated.
Same problem here. I ran
  • univention-remove --purge univention-ox* but script still reports “oxmail” etc. I do not need them. How to remove?
  • I also have this /etc/univention/templates/files/etc/ldap/slapd.conf.d/66oxforucs.acl but no idea how to proceed? Do I need this?
