Hello, I try to upgrade to Version 5 (from 4.4-errata1150), but it fails with:
python_ucr_template_compatibility:
The following UCR templates are not compatible with Python 3:
/etc/univention/templates/files/etc/ldap/slapd.conf.d/66oxforucs.acl
See <https://help.univention.com/t/17948> for information on how to proceed with each template.
/etc/univention/templates/files/etc/ldap/slapd.conf.d/20univention-kolab_schema (package: univention-legacy-kolab-schema)
/etc/univention/templates/files/usr/share/univention-management-console/www/config.php (package: univention-management-console)
I already read the article UCS 5.0 upgrade failed: solve pre-update check python-ucr-template-compatibility , but these files are not listed there. Also the updater said we’ve a kolab-ldap schema installed be never used this?!
Here is the rest of the error.log:
kolab_schema:
The package univention-legacy-kolab-schema is installed. This package is
incompatible with UCS 5.0-0.
As the package contains a LDAP schema extension, this extension (a) has to
registered in the LDAP database or (b) has to be removed before the update
to UCS 5.0 is possible.
Note: These steps are only required on the Primary Node. On non-primary systems,
the package can be removed without step (a) or (b).
(a) Register LDAP schema files from univention-legacy-kolab-schema:
To register the LDAP schema, run the following commands:
cat /usr/share/univention-ldap/schema/legacy/rfc2739.schema > /opt/kolab-legacy.schema
cat /usr/share/univention-ldap/schema/legacy/kolab2.schema >> /opt/kolab-legacy.schema
cat /usr/share/univention-ldap/schema/legacy/univention-kolab2.schema >> /opt/kolab-legacy.schema
cat /usr/share/univention-ldap/schema/legacy/kolab-legacy.schema >> /opt/kolab-legacy.schema
bash -c 'source /usr/share/univention-lib/ldap.sh && ucs_registerLDAPExtension --packagename "univention-legacy-kolab-schema" --packageversion "3.0.0-1.2
2.201309110849" --schema /opt/kolab-legacy.schema'
or (b) Remove the LDAP schema extension:
Please visit https://help.univention.com/t/6443 for how to remove LDAP schema extensions
(remove all attributes and objectclasses from that schema from the LDAP database).
After either (a) or (b) has been completed, the package has to be removed from this server:
univention-remove --purge univention-legacy-kolab-schema
minimum_ucs_version_of_all_systems_in_domain:
The following extensions are incompatible with UCS 5.0:
cn=66oxforucs,cn=ldapacl,cn=univention,dc=aei,dc=mpg,dc=de: [unspecified..unspecified)
cn=50_ox,cn=udm_syntax,cn=univention,dc=aei,dc=mpg,dc=de: [unspecified..unspecified)
cn=oxAccess,cn=udm_hook,cn=univention,dc=aei,dc=mpg,dc=de: [unspecified..unspecified)
cn=oxGroupHook,cn=udm_hook,cn=univention,dc=aei,dc=mpg,dc=de: [unspecified..unspecified)
cn=oxmail/oxcontext,cn=udm_module,cn=univention,dc=aei,dc=mpg,dc=de: [unspecified..unspecified)
cn=oxmail/oxdomain,cn=udm_module,cn=univention,dc=aei,dc=mpg,dc=de: [unspecified..unspecified)
cn=oxmail/oxfetchmailmulti,cn=udm_module,cn=univention,dc=aei,dc=mpg,dc=de: [unspecified..unspecified)
cn=oxmail/oxfetchmailsingle,cn=udm_module,cn=univention,dc=aei,dc=mpg,dc=de: [unspecified..unspecified)
cn=oxmail/oxfolder,cn=udm_module,cn=univention,dc=aei,dc=mpg,dc=de: [unspecified..unspecified)
cn=oxmail/oxlists,cn=udm_module,cn=univention,dc=aei,dc=mpg,dc=de: [unspecified..unspecified)
cn=oxmail/oxmail,cn=udm_module,cn=univention,dc=aei,dc=mpg,dc=de: [unspecified..unspecified)
cn=oxresources/oxresources,cn=udm_module,cn=univention,dc=aei,dc=mpg,dc=de: [unspecified..unspecified)
cn=oxUserDefaults,cn=udm_hook,cn=univention,dc=aei,dc=mpg,dc=de: [unspecified..unspecified)
cn=oxContextRW,cn=udm_hook,cn=univention,dc=aei,dc=mpg,dc=de: [unspecified..unspecified)
thanks in advanced!
