Hello, Bernd, I have now backed up all the data, deleted the entire Nextcloud installation including the Docker image, UCS variables, the specified folders and the database entries. The reinstallation has now been completed, but the join script is not executed properly (not even after restarting the server).
These are the corresponding entries in the LOG file:
`RUNNING 50nextcloud.inst
2020-12-13 11:09:52.047130977+01:00 (in joinscript_init)
Object exists: cn=services,cn=univention,dc=zabrana,dc=local
Object created: cn=Nextcloud Hub,cn=services,cn=univention,dc=zabrana,dc=local
Object modified: cn=ucs,cn=dc,cn=computers,dc=zabrana,dc=local
Create nextcloud/ucs/modifyUsersFilter
Create nextcloud/ucs/userEnabled
Create nextcloud/ucs/userQuota
Create nextcloud/ucs/debug
Create nextcloud/ldap/cacheTTL
Create nextcloud/ldap/homeFolderAttribute
Create nextcloud/ldap/userSearchAttributes
Create nextcloud/ldap/userDisplayName
Create nextcloud/ldap/groupDisplayName
Create nextcloud/ldap/base
Create nextcloud/ldap/baseUsers
Create nextcloud/ldap/baseGroups
Create nextcloud/ldap/filterLogin
Create nextcloud/ldap/filterUsers
Create nextcloud/ldap/filterGroups
Module: zarafa-cfg
Module: kopano-cfg
Object exists: cn=ldapschema,cn=univention,dc=zabrana,dc=local
INFO: No change of core data of object nextcloud.
No modification: cn=nextcloud,cn=ldapschema,cn=univention,dc=zabrana,dc=local
Waiting for activation of the extension object nextcloud: OK
Object created: cn=nextcloud,cn=custom attributes,cn=univention,dc=zabrana,dc=local
Object created: cn=nextcloudUserEnabled,cn=nextcloud,cn=custom attributes,cn=univention,dc=zabrana,dc=local
Object created: cn=nextcloudUserQuota,cn=nextcloud,cn=custom attributes,cn=univention,dc=zabrana,dc=local
Object created: cn=nextcloudGroupEnabled,cn=nextcloud,cn=custom attributes,cn=univention,dc=zabrana,dc=local
Object exists: SAMLServiceProviderIdentifier=https://ucs.zabrana.local/nextcloud/apps/user_saml/saml/metadata,cn=saml-serviceprovider,cn=univention,dc=zabrana,dc=local
Config value idp-x509cert for app user_saml set to -----BEGIN CERTIFICATE-----
MIIEszCCA5uxxx…==
-----END CERTIFICATE-----
Config value type for app user_saml set to saml
Config value general-require_provisioned_account for app user_saml set to 1
Config value general-allow_multiple_user_back_ends for app user_saml set to 1
Config value general-uid_mapping for app user_saml set to uid
Config value idp-singleLogoutService.url for app user_saml set to https://ucs-sso.zabrana.local/simplesamlphp/saml2/idp/SingleLogoutService.php
Config value idp-singleSignOnService.url for app user_saml set to https://ucs-sso.zabrana.local/simplesamlphp/saml2/idp/SSOService.php
Config value idp-entityId for app user_saml set to https://ucs-sso.zabrana.local/simplesamlphp/saml2/idp/metadata.php
curl failed with error 51
Failed to request an LDAP config id from Nextcloud
EXITCODE=1
3f292d40-a799-4b24-94ce-9d3707805d9e`
Unfortunately, that doesn’t say too much to me. Do you have a tip for me?
Thanks Helmut
