Update auf 5.0-4 schlägt fehl
Das Update auf UCS 5.0-4 schlägt fehl. Aus dem update.log auf welches verwiesen wird, werde ich nicht so recht schlau.
Starting univention-upgrade. Current UCS version is 5.0-3 errata716
Checking for local repository:                          none
Checking for package updates:                           none
Checking for app updates:                               none
Checking for release updates:                           found: UCS 5.0-4
Starting update to UCS version 5.0-4 at Fri Jun 23 16:30:34 2023...
23.06.23 16:30:36.032  DEBUG_INIT
**** Starting univention-updater 5.0-3 with parameter=['/usr/share/univention-updater/univention-updater', 'net', '--updateto', '5.0-4', '--silent', '--ignoreterm']
--->DBG:update_available(mode=net)
Checking network repository
Update to = 5.0-4
**** Downloading scripts at Fri Jun 23 16:30:37 2023
**** Starting actual update at Fri Jun 23 16:30:39 2023
Starting /tmp/tmpksc2ofgg/https:__updates.software-univention.de_dists_ucs504_preup.sh (Fr 23. Jun 16:30:39 CEST 2023):
HINT:
Please check the release notes carefully BEFORE updating to UCS 5.0-4:
 English version: https://docs.software-univention.de/release-notes/5.0-4/en/
 German version:  https://docs.software-univention.de/release-notes/5.0-4/de/
3rd party components.
Do you want to continue [Y/n]?
Checking disk_space ...                           OK
Checking failed_ldif ...                          OK
Checking hold_packages ...                        OK
Checking kernel ...                               OK
Checking ldap_connection ...                      OK
Checking ldap_schema ...                          OK
Checking master_version ...                       OK
Checking minimum_ucs_version_of_all_systems_in_domain ... OK
Checking overwritten_umc_templates ...            OK
Checking package_status ...                       OK
Checking role_package_removed ...                 OK
Checking slapd_on_member ...                      OK
Checking ssh ...                                  OK
Checking system_date_too_old ...                  OK
Checking term ...                                 OK
Checking valid_machine_credentials ...            OK
Paketlisten werden gelesen...
Abhängigkeitsbaum wird aufgebaut....
Statusinformationen werden eingelesen....
0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
Ign:1 https://appcenter.software-univention.de/univention-repository/5.0/maintained/component kopano-core_20220630105644/all/ InRelease
OK:2 https://updates.software-univention.de ucs504 InRelease
OK:3 https://updates.software-univention.de ucs503 InRelease
Ign:4 https://appcenter.software-univention.de/univention-repository/5.0/maintained/component kopano-core_20220630105644/amd64/ InRelease
OK:5 https://updates.software-univention.de errata503 InRelease
Ign:6 https://appcenter.software-univention.de/univention-repository/5.0/maintained/component letsencrypt_20211006103329/all/ InRelease
Ign:7 https://appcenter.software-univention.de/univention-repository/5.0/maintained/component letsencrypt_20211006103329/amd64/ InRelease
Ign:8 https://appcenter.software-univention.de/univention-repository/5.0/maintained/component z-push-kopano_20211125121614/all/ InRelease
Ign:9 https://appcenter.software-univention.de/univention-repository/5.0/maintained/component z-push-kopano_20211125121614/amd64/ InRelease
Ign:10 https://appcenter.software-univention.de/univention-repository/5.0/maintained/component kopano-webapp_20220622120718/all/ InRelease
Ign:11 https://appcenter.software-univention.de/univention-repository/5.0/maintained/component kopano-webapp_20220622120718/amd64/ InRelease
OK:12 https://appcenter.software-univention.de/univention-repository/5.0/maintained/component kopano-core_20220630105644/all/ Release
OK:13 https://appcenter.software-univention.de/univention-repository/5.0/maintained/component kopano-core_20220630105644/amd64/ Release
OK:14 https://appcenter.software-univention.de/univention-repository/5.0/maintained/component letsencrypt_20211006103329/all/ Release
OK:15 https://appcenter.software-univention.de/univention-repository/5.0/maintained/component letsencrypt_20211006103329/amd64/ Release
OK:16 https://appcenter.software-univention.de/univention-repository/5.0/maintained/component z-push-kopano_20211125121614/all/ Release
OK:17 https://appcenter.software-univention.de/univention-repository/5.0/maintained/component z-push-kopano_20211125121614/amd64/ Release
OK:18 https://appcenter.software-univention.de/univention-repository/5.0/maintained/component kopano-webapp_20220622120718/all/ Release
OK:19 https://appcenter.software-univention.de/univention-repository/5.0/maintained/component kopano-webapp_20220622120718/amd64/ Release
Holen:21 https://download.kopano.io/supported/core:/8.7/Univention_5.0  InRelease [1.876 B]
Holen:22 https://download.kopano.io/supported/archiver:/8.7/Univention_5.0  InRelease [1.876 B]
Holen:24 https://download.kopano.io/supported/webapp:/final/Univention_5.0  InRelease [1.876 B]
Holen:25 https://download.kopano.io/supported/files:/final/Univention_5.0  InRelease [1.876 B]
Holen:27 https://download.kopano.io/supported/mdm:/final/Univention_5.0  InRelease [1.876 B]
Holen:28 https://download.kopano.io/supported/smime:/final/Univention_5.0  InRelease [1.876 B]
Holen:30 https://download.kopano.io/zhub/z-push:/final/Univention_5.0  InRelease [2.632 B]
Fehl:21 https://download.kopano.io/supported/core:/8.7/Univention_5.0  InRelease
  Die folgenden Signaturen waren ungültig: EXPKEYSIG 5CB27E1358E2F2A7 Kopano Development <development@kopano.io>
Fehl:22 https://download.kopano.io/supported/archiver:/8.7/Univention_5.0  InRelease
Fehl:24 https://download.kopano.io/supported/webapp:/final/Univention_5.0  InRelease
Fehl:25 https://download.kopano.io/supported/files:/final/Univention_5.0  InRelease
Fehl:27 https://download.kopano.io/supported/mdm:/final/Univention_5.0  InRelease
Fehl:28 https://download.kopano.io/supported/smime:/final/Univention_5.0  InRelease
Fehl:30 https://download.kopano.io/zhub/z-push:/final/Univention_5.0  InRelease
W: Ziel Packages (Packages) ist mehrfach konfiguriert in /etc/apt/sources.list.d/00_ucs_temporary_installation.list:2 und /etc/apt/sources.list.d/20_ucs-online-component.list:11
W: Ziel Packages (Packages) ist mehrfach konfiguriert in /etc/apt/sources.list.d/00_ucs_temporary_installation.list:3 und /etc/apt/sources.list.d/20_ucs-online-component.list:12
W: Ziel Packages (Packages) ist mehrfach konfiguriert in /etc/apt/sources.list.d/00_ucs_temporary_installation.list:4 und /etc/apt/sources.list.d/20_ucs-online-component.list:15
W: Ziel Packages (Packages) ist mehrfach konfiguriert in /etc/apt/sources.list.d/00_ucs_temporary_installation.list:5 und /etc/apt/sources.list.d/20_ucs-online-component.list:16
W: Ziel Packages (Packages) ist mehrfach konfiguriert in /etc/apt/sources.list.d/00_ucs_temporary_installation.list:6 und /etc/apt/sources.list.d/20_ucs-online-component.list:17
W: Ziel Packages (Packages) ist mehrfach konfiguriert in /etc/apt/sources.list.d/00_ucs_temporary_installation.list:7 und /etc/apt/sources.list.d/20_ucs-online-component.list:18
W: Ziel Packages (Packages) ist mehrfach konfiguriert in /etc/apt/sources.list.d/00_ucs_temporary_installation.list:8 und /etc/apt/sources.list.d/20_ucs-online-component.list:13
W: Ziel Packages (Packages) ist mehrfach konfiguriert in /etc/apt/sources.list.d/00_ucs_temporary_installation.list:9 und /etc/apt/sources.list.d/20_ucs-online-component.list:14
W: GPG-Fehler: https://download.kopano.io/supported/core:/8.7/Univention_5.0  InRelease: Die folgenden Signaturen waren ungültig: EXPKEYSIG 5CB27E1358E2F2A7 Kopano Development <development@kopano.io>
E: Das Depot »https://download.kopano.io/supported/core:/8.7/Univention_5.0  InRelease« ist nicht signiert.
W: GPG-Fehler: https://download.kopano.io/supported/archiver:/8.7/Univention_5.0  InRelease: Die folgenden Signaturen waren ungültig: EXPKEYSIG 5CB27E1358E2F2A7 Kopano Development <development@kopano.io>
E: Das Depot »https://download.kopano.io/supported/archiver:/8.7/Univention_5.0  InRelease« ist nicht signiert.
W: GPG-Fehler: https://download.kopano.io/supported/webapp:/final/Univention_5.0  InRelease: Die folgenden Signaturen waren ungültig: EXPKEYSIG 5CB27E1358E2F2A7 Kopano Development <development@kopano.io>
E: Das Depot »https://download.kopano.io/supported/webapp:/final/Univention_5.0  InRelease« ist nicht signiert.
W: GPG-Fehler: https://download.kopano.io/supported/files:/final/Univention_5.0  InRelease: Die folgenden Signaturen waren ungültig: EXPKEYSIG 5CB27E1358E2F2A7 Kopano Development <development@kopano.io>
E: Das Depot »https://download.kopano.io/supported/files:/final/Univention_5.0  InRelease« ist nicht signiert.
W: GPG-Fehler: https://download.kopano.io/supported/mdm:/final/Univention_5.0  InRelease: Die folgenden Signaturen waren ungültig: EXPKEYSIG 5CB27E1358E2F2A7 Kopano Development <development@kopano.io>
E: Das Depot »https://download.kopano.io/supported/mdm:/final/Univention_5.0  InRelease« ist nicht signiert.
W: GPG-Fehler: https://download.kopano.io/supported/smime:/final/Univention_5.0  InRelease: Die folgenden Signaturen waren ungültig: EXPKEYSIG 5CB27E1358E2F2A7 Kopano Development <development@kopano.io>
E: Das Depot »https://download.kopano.io/supported/smime:/final/Univention_5.0  InRelease« ist nicht signiert.
W: GPG-Fehler: https://download.kopano.io/zhub/z-push:/final/Univention_5.0  InRelease: Die folgenden Signaturen waren ungültig: EXPKEYSIG 5CB27E1358E2F2A7 Kopano Development <development@kopano.io>
E: Das Depot »https://download.kopano.io/zhub/z-push:/final/Univention_5.0  InRelease« ist nicht signiert.
** Starting: apt-get -s -o Debug::pkgProblemResolver=yes dist-upgrade
Paketaktualisierung (Upgrade) wird berechnet...Starting pkgProblemResolver with broken count: 0
Starting 2 pkgProblemResolver with broken count: 0
Done
Starting update process, this may take a while.
Check /var/log/univention/updater.log for more information.
Fr 23. Jun 16:30:52 CEST 2023
OK:1 https://updates.software-univention.de ucs504 InRelease
Ign:2 https://appcenter.software-univention.de/univention-repository/5.0/maintained/component kopano-core_20220630105644/all/ InRelease
Holen:23 https://download.kopano.io/supported/archiver:/8.7/Univention_5.0  InRelease [1.876 B]
Holen:26 https://download.kopano.io/supported/files:/final/Univention_5.0  InRelease [1.876 B]
Holen:28 https://download.kopano.io/supported/mdm:/final/Univention_5.0  InRelease [1.876 B]
Holen:29 https://download.kopano.io/supported/smime:/final/Univention_5.0  InRelease [1.876 B]
Fehl:23 https://download.kopano.io/supported/archiver:/8.7/Univention_5.0  InRelease
Fehl:26 https://download.kopano.io/supported/files:/final/Univention_5.0  InRelease
Fehl:28 https://download.kopano.io/supported/mdm:/final/Univention_5.0  InRelease
Fehl:29 https://download.kopano.io/supported/smime:/final/Univention_5.0  InRelease
Error: Failed to execute "apt-get update"
Vielleicht weiß hierzu jemand von Euch Hilfe.
Vielen Dank schonmal …
Kopano repos deaktivieren
Vielen Dank für die Antwort.
Die Repos müssen wohl deaktiviert bleiben, damit dann auch zukünftig die Updates passen, oder? Offensichtlich hat das aber keinen Einfluss auf Kopano Groupware.
Danke nochmal.
