How can I unjoin a computer ?
Best Regards,
Cordaliss
Best Regards,
Cordaliss
you can simply remove the computer object in the UMC computer module.
Regards,
Tim Petersen
Thank you Tim !
I have done that, but after i reinstall the server when i try to join the slave again i get error that the mac address already exists…
How can i clean the remaning information of old server?
I don’t know but you are right, they stay some trace of old slave computer.
Actually I have some issues to install application after delete the slave and rejoin the slave.
it’s will be good to have a kind of clean up script.
