I created an extended attribute univentionFreeAttribute1 to add info to Users and Contacts.
On the Users, it works OK, but on the Contacts I keep getting this error:
The LDAP object could not be saved: LDAP Error Object class violation: attribute ‘univentionFreeAttribute1’ not allowed
Any ideas why?
Hi!
The contacts in UCS are just what they are supposed to be: contact. They have only a limited set of object classes and do not support extended attributes.
Sorry for this
/CV
Hello Christian,
Thank you for your fast and concise response.
Can I ask:
- what objects support the extended attributes? Just users?
- Is there any way to enable this support for other objects?
Thanks,
FM
