Univention-upgrade 5.0-9 to 5.1.0
Hi Community,
I try to do the upgrade the next version but I’m stuck with this message, please could you help me.
The update to UCS 5.1-0 is blocked because the components ‘open-xchange-guard_20240905154826’, ‘open-xchange-text_20240122133346’, ‘oxseforucs_20240306095834’ are marked as required…
Thank you.,
the oxseforucs App is not yet available for UCS 5.2 (5.1). Therefore the updater blocks the update and returns this message.
We are currently working on making the available for UCS 5.2.
Best regards,
Felix
I’m running into this issue as well. Is there an estimate when it will be available?
The update to UCS 5.1-0 is blocked because the component ‘oxseforucs_20240306095834’ is marked as required.
hello, just wondering if this is still being worked on?
Moin,
let me quote what I just wrote in another thread:
Regards
Jan-Luca
