Hallo Leute,
wenn ich einen Univention Server Upgrade, bekomme ich gerade immer folgenden Fehler:
Starting univention-upgrade. Current UCS version is 4.3-3 errata504
Checking for package updates: none
Checking for app updates: none
Checking for release updates: found: UCS 4.3-4
Starting update to UCS version 4.3-4
HINT:
Please check the release notes carefully BEFORE updating to UCS 4.3-4:
English version: https://docs.software-univention.de/release-notes-4.3-4-en.html
German version: https://docs.software-univention.de/release-notes-4.3-4-de.html
3rd party components.
Update will wait here for 60 secondsā¦
Press CTRL-c to abort or press ENTER to continue
Checking for space on /var/cache/apt/archives: OK
Checking for space on /boot: OK
Checking for space on /: OK
Checking for package status: failed
ERROR: The package state on this system is inconsistent.
Please run ādpkg --configure -aā manually
Error: Please check ā/var/log/univention/updater.logā for details.
root@mail:/var/lib/univention-ldap/ldap# dpkg --configure -a
bind9 (1:9.10.3.dfsg.P4-12.3+deb9u5A~4.3.0.201905131409) wird eingerichtet ā¦
insserv: Service samba-ad-dc has to be enabled to start service bind9
insserv: exiting now!
update-rc.d: error: insserv rejected the script header
dpkg: Fehler beim Bearbeiten des Paketes bind9 (āconfigure):
Unterprozess installiertes post-installation-Skript gab den Fehlerwert 1 zurück
bind9
root@mail:/var/lib/univention-ldap/ldap# ucr get server/role
domaincontroller_slave
root@mail:/var/lib/univention-ldap/ldap# ucr get dns/backend
ldap
Was kann ich tun?
