I have quite the problem with Univention and I hope soemone can help me.
I have a virtual server with 80GB of virtual hdd running versione 4.4.9 and SuiteCrm.
Today it stopped working becoming unresponsive and/or unreachable.
I did some checks and it seems that it’s somehow out of space since while trying to update it i was getting with the no space available" error.
At this point I have 3 options:
Free some space to solve the problem
Expand it (I have increased the virtual hdd and expanded the partitions while booting gparted but no results)
No, that wasn’t much either. If this is not limited, the directory can be very large.
You can only analyse your vmspace:
du -sh /*
Then switch to the next Subdirectory where there is the most data or where you think there might be data to delete.
You also can do an “apt autoremove --purge” but with care, and an “apt clean”.
You enlarged the PHY partition, then the VG, then the LV and finally the filesystem? How exactly did you do that?
I checked with du -sh but the only folder “big” is /usr which is only 2.2GB
In any case I am probably a noob but I don’t understand:
df -h say that I have 59GB free but if I run univention-upgrade it fails for no space and then everyhting fails.
Same if I try sudo apt-get update or upgrade.
The Expand was an otion. I am trying to expand it but due to lack of knowledge I am unable to execute it.
I can expand the disk, enlarge the partition but then the VM still report the old size. Googling is not helping since I am hitting multiple solutions and or errors.
Ah sorry, my fault, i’ve overseen that 100% is only on inodes on your screenshot…
A way is to create a new partition an move the CRM to it. This is where most of the files will be hidden. But otherwise here are some instructions for enlarging your LVM.
Many , many thanks for the second link. It worked.
I just did a couple of changes.
I extended the virtual HDD from my hypervisor when the VM was off.
Then I booted into Gparted to create an ext4 partition and rebooted.
I followed the second link but instead of xfs_growfs i used resize2fs since my partition are ext4.
Another reboot and finally df -i show 80% of usage.
Now SuiteCRM is working again.
Next move is to move away from UCS since during this journey I discovered that SuiteCRM is not supported anymore.
