I have a master server and a backup server that showed no failures or errors before the update.
After updating the system to 5.2, the master server presented the following error.
“The following KDCs were unreachable: tcp srvad2.cnsd.local:88, udp srvad2.cnsd.local:88”
And the backup server had a critical error.
"“univention-check-join-status” returned a problem with the domain join.
STDOUT: Warning: ‘univention-samba4’ is not configured. Warning: ‘univention-samba4-dns’ is not configured. Error: Not all install files configured: 2 missing
See Manual: Analysis of listener/notifier problems or run the join-scripts via “Domain join” module."
I reviewed the settings with the backup file and they are unchanged.
How can I check more details and resolve these errors?
since I’m running in the same issue, two short questions:
1.) should the “univention-run-join-scripts” run on the primary node or the backup node?
2.) should the fix be executed on the primary or the secondary and then be followed by an additional join?
[EDIT]
The error message is as follows on the backup node:
2026-03-26 11:56:48.159337167+01:00 (in joinscript_init)
Samba4 backend database not available yet, exiting joinscript 98univention-samba4-dns.
EXITCODE=1
[EDIT2]
the following message is shown on the primary node: samba-tool drs showrepl gibt ein Problem mit der Replikation zurück.
In eingehend ‘DC=ForestDnsZones,DC=domain,DC=de’: Fehler während der DRS Replikation von Default-First-Site-Name/UCS5 (WERR_FILE_NOT_FOUND).
In eingehend ‘DC=DomainDnsZones,DC=domain,DC=de’: Fehler während der DRS Replikation von Default-First-Site-Name/UCS5 (WERR_FILE_NOT_FOUND).
In eingehend ‘DC=domain,DC=de’: Fehler während der DRS Replikation von Default-First-Site-Name/UCS5 (WERR_FILE_NOT_FOUND).
In eingehend ‘CN=Schema,CN=Configuration,DC=domain,DC=de’: Fehler während der DRS Replikation von Default-First-Site-Name/UCS5 (WERR_FILE_NOT_FOUND).
In eingehend ‘CN=Configuration,DC=domain,DC=de’: Fehler während der DRS Replikation von Default-First-Site-Name/UCS5 (WERR_FILE_NOT_FOUND).
In ausgehend ‘DC=ForestDnsZones,DC=domain,DC=de’: Fehler während der DRS Replikation nach Default-First-Site-Name/UCS5 (WERR_FILE_NOT_FOUND).
In ausgehend ‘DC=DomainDnsZones,DC=domain,DC=de’: Fehler während der DRS Replikation nach Default-First-Site-Name/UCS5 (WERR_FILE_NOT_FOUND).
In ausgehend ‘DC=domain,DC=de’: Fehler während der DRS Replikation nach Default-First-Site-Name/UCS5 (WERR_FILE_NOT_FOUND).
In ausgehend ‘CN=Configuration,DC=domain,DC=de’: Fehler während der DRS Replikation nach Default-First-Site-Name/UCS5 (WERR_FILE_NOT_FOUND).
