On the portal that first loads before login it is showing software I have since uninstalled, How do I remove items from this list.
You have to navigate to “univivention/portal” with the UMC module “LDAP directory”. There you can find the correlating LDAP objects. If you delete the correct objects, the entries will vanish.
https://docs.software-univention.de/manual-4.2.html#central:portal
Thank you for your help
