Univention Office365 not syncing the users
Tried the office 365, but the sync is not happening. Could you please have a look on this logs
ty02.11.17 09:43:45.804  LISTENER    ( ERROR   ) : o365(I): azure_handler._create_object:278  Creating user with properties: {'passwordProfile': {'password': '******', 'forceChangePasswordNextLogin': False}, 'accountEnabled': True, 'surname': 'test', 'mailNickname': 'test', 'userPrincipalName': 'test@devopsin.com', 'immutableId': 'NWZjYzM0OGEtNTQxYi0xMDM3LTgzOWMtMmRkMDJhZTA4ZDBl', 'otherMails': ['test@devops.in'], 'displayName': 'test', 'usageLocation': 'US'}
02.11.17 09:43:45.805  LISTENER    ( ERROR   ) : o365(D): azure_auth.get_access_token:341  Loading token from disk...
02.11.17 09:43:45.806  LISTENER    ( ERROR   ) : o365(D): azure_auth.get_access_token:346  Token expired, retrieving now one from azure...
02.11.17 09:43:45.854  LISTENER    ( ERROR   ) : o365(D): azure_auth.retrieve_access_token:502  POST to URL='https://login.microsoftonline.com/71f78fec-7013-49a4-aba0-747f99e381ec/oauth2/token' with data={'resource': 'https://graph.windows.net', 'client_assertion_type': 'urn:ietf:params:oauth:client-assertion-type:jwt-bearer', 'redirect_uri': u'http://10.10.10.133/univention/command/office365/authorize', 'client_assertion': 'eyJ4NXQiOiAiKzlwN3ZGcFpvd2RrTUN0elQ2bURZcHkrOEk4PSIsICJhbGciOiAiUlMyNTYifQ.eyJhdWQiOiAiaHR0cHM6Ly9sb2dpbi5taWNyb3NvZnRvbmxpbmUuY29tLzcxZjc4ZmVjLTcwMTMtNDlhNC1hYmEwLTc0N2Y5OWUzODFlYy9vYXV0aDIvdG9rZW4iLCAiaXNzIjogIjQyY2IxNzBkLTkwNTMtNDIyYi1hNjdiLWFiZGY5ZDE5NGUyMiIsICJqdGkiOiAiMjdjNjQzNTEtMTk2Mi00YjkxLThjYTctNDc0NGQyNDZiZjJlIiwgImV4cCI6IDE1MDk2MzA4MjUsICJuYmYiOiAxNTA5NjI5OTI1LCAic3ViIjogIjQyY2IxNzBkLTkwNTMtNDIyYi1hNjdiLWFiZGY5ZDE5NGUyMiJ9.ZlvHJkc64xOE32kmy3uZlj_TltY5AtsQzKjZ43jjpgMWAjB5VkFL2gtdw3oM0PDGero6TTSAP5WU3AscT34IDjCBZa8ZKhjZEMRdcO--xm7X4Pyz93rdohL3_v37RS5PtUNDm6DnoLIspzEVFWXq6iPa-SnqIyjWP3Td3cTEpfJj2732MKG3c9mkipQBEs6Kf5Q0cKN33SWsPlGsEykZHTrCWU37gvwT5OQSB1Dl_1J_bg6xmbNg99MhxEJUASp_D4G9E1h_Lmq0D1n6TkyFOA2r67_8NRBIM5B4i_IbSasQfNTdM6JzYPHaDx3PnXBvpAthHUX9kUvscfHHWlsFew', 'client_id': u'42cb170d-9053-422b-a67b-abdf9d194e22', 'scope': ['Directory.ReadWrite.All'], 'grant_type': 'client_credentials'}
02.11.17 09:43:46.297  LISTENER    ( ERROR   ) : o365(E): azure_auth.retrieve_access_token:506  Error retrieving token (status 401), response: {'cookies': <RequestsCookieJar[Cookie(version=0, name='esctx', value='AQABAAAAAABHh4kmS_aKT5XrjzxRAtHzHN_5BXUz3zk1Z39Rwg8a1dAnLJs2UmLcvNhZVyKsRGtCQT5L4u3O8FzIJyZ3jLlFmzSiozq5mk_Z96ZfdDRbtQVKhfJd_bB1DbpcsGsDenOvtsU5-s8tpeM4CIzpeR-lxBXxNej_fYxgybHVqH1kr8GkqY4ZWMWnTc7nfh3rSPsgAA', port=None, port_specified=False, domain='.login.microsoftonline.com', domain_specified=True, domain_initial_dot=True, path='/', path_specified=True, secure=True, expires=None, discard=True, comment=None, comment_url=None, rest={'HttpOnly': None}, rfc2109=False), Cookie(version=0, name='stsservicecookie', value='ests', port=None, port_specified=False, domain='login.microsoftonline.com', domain_specified=False, domain_initial_dot=False, path='/', path_specified=True, secure=True, expires=None, discard=True, comment=None, comment_url=None, rest={'HttpOnly': None}, rfc2109=False), Cookie(version=0, name='x-ms-gateway-slice', value='008', port=None, port_specified=False, domain='login.microsoftonline.com', domain_specified=False, domain_initial_dot=False, path='/', path_specified=True, secure=True, expires=None, discard=True, comment=None, comment_url=None, rest={'HttpOnly': None}, rfc2109=False)]>, '_content': '{"error":"invalid_client","error_description":"AADSTS70002: Error validating credentials. AADSTS50012: Client assertion contains an invalid signature. [Reason - The key was not found., Thumbprint of key used by client: \'FBDA7BBC5A59A30764302B734FA983629CBEF08F\', Configured keys: []]\\r\\nTrace ID: 9c809997-7c0c-4fb4-b9b1-ff45aa957700\\r\\nCorrelation ID: 3e71c413-514b-4cf1-8d36-b2bca99e8d9d\\r\\nTimestamp: 2017-11-02 13:43:48Z","error_codes":[70002,50012],"timestamp":"2017-11-02 13:43:48Z","trace_id":"9c809997-7c0c-4fb4-b9b1-ff45aa957700","correlation_id":"3e71c413-514b-4cf1-8d36-b2bca99e8d9d"}', 'headers': {'content-length': '595', 'expires': '-1', 'x-content-type-options': 'nosniff', 'x-powered-by': 'ASP.NET', 'set-cookie': 'esctx=AQABAAAAAABHh4kmS_aKT5XrjzxRAtHzHN_5BXUz3zk1Z39Rwg8a1dAnLJs2UmLcvNhZVyKsRGtCQT5L4u3O8FzIJyZ3jLlFmzSiozq5mk_Z96ZfdDRbtQVKhfJd_bB1DbpcsGsDenOvtsU5-s8tpeM4CIzpeR-lxBXxNej_fYxgybHVqH1kr8GkqY4ZWMWnTc7nfh3rSPsgAA; domain=.login.microsoftonline.com; path=/; secure; HttpOnly, x-ms-gateway-slice=008; path=/; secure; HttpOnly, stsservicecookie=ests; path=/; secure; HttpOnly', 'x-ms-request-id': '9c809997-7c0c-4fb4-b9b1-ff45aa957700', 'strict-transport-security': 'max-age=31536000; includeSubDomains', 'server': 'Microsoft-IIS/8.5', 'pragma': 'no-cache', 'cache-control': 'no-cache, no-store', 'date': 'Thu, 02 Nov 2017 13:43:48 GMT', 'p3p': 'CP="DSP CUR OTPi IND OTRi ONL FIN"', 'content-type': 'application/json; charset=utf-8'}, 'url': u'https://login.microsoftonline.com/71f78fec-7013-49a4-aba0-747f99e381ec/oauth2/token', 'status_code': 401, '_content_consumed': True, 'encoding': 'utf-8', 'request': <PreparedRequest [POST]>, 'connection': <requests.adapters.HTTPAdapter object at 0x7f1858042d90>, 'elapsed': datetime.timedelta(0, 0, 380440), 'raw': <urllib3.response.HTTPResponse object at 0x7f1858049f10>, 'reason': 'Unauthorized', 'history': []}
None
pe or paste code here
The connection has not been authenticated.
Did the configuration wizard run through successfully?
It ended up on authentication token error eventhough the steps were followed
Could you please list out the possibilities why that happens eventhough the same steps are followed.
Error retrieving authentication token from Azure. Getting like this when trying to setup
Good afternoon augustineca,
sorry I have no idea on how to solve this problem. Maybe the support team can help you. Below is a link to the channel:
Regards
Anna Takang
