r100gs
February 12, 2021, 9:17am
1
Nextcloud and Bitwarden_rs complains about a certificate failure.
I searched arround a little bit and some people say I should use a fullchain.pem
But in /etc/univention/letsencrypt there is no such file.
Where can I get it from?
Best regards,
Stefan
What certificate files do you find in /etc/univention/letsencrypt?
r100gs
February 15, 2021, 5:41am
3
account.key intermediate-r3.pem signed_chain.crt_20190301-051508 signed_chain.crt_20191101-033029 signed_chain.crt_20210128-074219
chained.pem post-refresh.d signed_chain.crt_20190401-033017 signed_chain.crt_20191201-033025 signed_chain.crt_20210128-074851
chained.pem_20180114-202406 setup.d signed_chain.crt_20190508-091814 signed_chain.crt_20200111-190903 signed_chain.crt_20210128-183051
chained.pem_20180114-202650 signed_chain.crt signed_chain.crt_20190601-033024 signed_chain.crt_20200111-191127 signed_chain.crt_20210128-185723
chained.pem_20180114-202710 signed_chain.crt_20180602-124740 signed_chain.crt_20190701-033020 signed_chain.crt_20200201-033035 signed_chain.crt_20210201-033057
chained.pem_20180201-033016 signed_chain.crt_20180602-124755 signed_chain.crt_20190701-150328 signed_chain.crt_20200301-033046 signed.crt
chained.pem_20180401-033107 signed_chain.crt_20180619-093153 signed_chain.crt_20190701-150646 signed_chain.crt_20200327-202808 signed.crt_20180114-202406
chained.pem_20180404-160915 signed_chain.crt_20180701-033012 signed_chain.crt_20190701-150707 signed_chain.crt_20200401-033045 signed.crt_20180114-202650
chained.pem_20180501-033020 signed_chain.crt_20180801-033021 signed_chain.crt_20190701-215807 signed_chain.crt_20200501-033027 signed.crt_20180114-202710
chained.pem_20180601-033017 signed_chain.crt_20180901-033018 signed_chain.crt_20190701-223638 signed_chain.crt_20200601-033030 signed.crt_20180201-033016
domain.csr signed_chain.crt_20181001-033018 signed_chain.crt_20190701-233013 signed_chain.crt_20200701-033027 signed.crt_20180401-033107
domain.key signed_chain.crt_20181101-033015 signed_chain.crt_20190801-033023 signed_chain.crt_20200801-033034 signed.crt_20180404-160915
domains signed_chain.crt_20181201-033016 signed_chain.crt_20190901-033022 signed_chain.crt_20200925-063900 signed.crt_20180501-033020
intermediate.pem signed_chain.crt_20190301-051452 signed_chain.crt_20191001-033050 signed_chain.crt_20201101-033034 signed.crt_20180601-033017
The fullchain.pem is needed on other systems.
On UCS you need
SSLCertificateChainFile /etc/univention/letsencrypt/signed_chain.crt
I did not update the Letsencrypt app to the lastest version. A few weeks ago I had a different setup:
SSLCertificateChainFile /etc/univention/letsencrypt/intermediate.pem
but this lead to a warning message starting this year.
r100gs
February 17, 2021, 5:37am
5
OK, I get an error using nextcloud all the time. There is some problem with my certificate in nextcloud.
Before everything was working fine
r100gs
February 17, 2021, 1:00pm
6
Since 2017 everything was working perfect, but now, with this wired certificate issue, its almost useless to me.
What does System-dianosis tell about the certificates?
(Univention UI - System - System-diagnosis)
Is the certificate in your Univention ui ok?
Is the certificate in your nextcloud app the same as on your Univention UI?
Are the cerificate in your apps from the same issuer?
Did you check the apache logs for error messages?
Are the univention registry variables set as I wrote above?
r100gs
February 18, 2021, 5:36am
8
Systemdiagnose:
certificate in browser is ok
For nextcloud I think so, I have installed it via app in univention
apache2/ssl/certificate /etc/univention/letsencrypt/signed_chain.crt
apache2/ssl/certificatechain /etc/univention/letsencrypt/intermediate.pem
apache2/ssl/key /etc/univention/letsencrypt/domain.key
appcenter/apps/letsencrypt/status installed
appcenter/apps/letsencrypt/ucs 4.4
appcenter/apps/letsencrypt/version 1.2.2-16
appcenter/prudence/docker/letsencrypt yes
kopano/cfg/ical/ssl_certificate_file /etc/univention/letsencrypt/intermediate.pem
kopano/cfg/ical/ssl_private_key_file /etc/univention/letsencrypt/domain.key
letsencrypt/domains **********
letsencrypt/services/apache2 true
letsencrypt/services/dovecot false
letsencrypt/services/postfix true
letsencrypt/staging false
letsencrypt/status Certificate refreshed at Mo 1. Feb 03:30:57 CET 2021
letsencrypt/v2migrated true
mail/postfix/ssl/cafile /etc/univention/letsencrypt/signed_chain.crt
mail/postfix/ssl/certificate /etc/univention/letsencrypt/signed_chain.crt
mail/postfix/ssl/key /etc/univention/letsencrypt/domain.key
repository/online/component/letsencrypt_20210118111509 enabled
repository/online/component/letsencrypt_20210118111509/description Let's Encrypt
repository/online/component/letsencrypt_20210118111509/localmirror false
repository/online/component/letsencrypt_20210118111509/server https://appcenter.software-univention.de
repository/online/component/letsencrypt_20210118111509/version current
Looks good.
But what exactly is the error message in Nextcloud?
Do you get shown the correct certificate after clicking the lock symbol in the browser’s addressbar and “View details”?
r100gs
February 18, 2021, 8:04am
10
My problem is with nextcloud app on android. It always tells me to check certificate.
Next problem is with my homeassistant installation which checks nextcloud caldev calendar
Phonetrack (android logging app based on nextcloud server) has problem with certificate
bitwarden_rs is not working anymore because of certificate issue (in bitwarden forums I found the solution with fullchain.pem)
Its not working anymore, which was fine since 2019. Now I always get a certificate error
NExtcloud in browser is fine
If I test the certificate with ssllabs.com I get a chain issue:
Additional Certificates (if supplied)
Certificates provided 2 (2828 bytes)
Chain issues Incomplete, Extra certs
The problem is that an old intermediate certificate is used if you have the Lets Encrypt app installed for quite a while. After changing apache2/ssl/certificatechain from /etc/univention/letsencrypt/intermediate.pem to /etc/univention/letsencrypt/intermediate-r3.pem curl is happy again and the bitwarden cli works as well.
(In case of my bitwarden_rs project you need to rerun start-bitwarden_rs.sh after correcting the ucr variable)
r100gs
March 1, 2021, 12:00pm
12
Hello fbartels!
THX, you made my day!
Everything is fine again!
