I have searched and searched but cannot find anything in the forums that answer my question here.
I have a very basic UCS set up, just two UCS servers, one primary with file server, the other secondary with mail server - nothing else.
Somehow, I have messed up my primary server so now absolutely nothing works - I can’t log in as any domain users via samba, web-console, ssh, etc. only root via ssh works. I think this had something to do with me accidentally removing the kernel (silly mistake, but I reinstalled the kernel and the system boots) or an apt autoremove. Not sure which did it, but since then this problem has occurred.
If I try to run something like univention-ldapsearch, I get the response ldap_bind: Invalid credentials (49)
univention-check-join-status errors with Error: ldapsearch -x failed
and if I try to run univention-run-join-scripts --ask-pass -dcaccount administrator --force --run-scripts 10univention-ldap-server.inst I get the response Message: binddn for user administrator not found
However, running kinit administrator and entering the password works and klist works after that too.
Some something is messed up, I think it has something to do with the machine.secret not matching, but I can’t reset that via udm as I get an “Authentication failed” error.
Can anybody help me with what I can check next? I believe all services are running and it’s just a computer authentication issue, but if you think otherwise I’m happy to check other things.
Thanks for your help!
