Univention-join to Active Directory
I should put UCS instead of an old SBS2011 server.
To get started, i tried to install UCS and clicked join Active Directory Domain during the install process.
Unfortunately several scripts failed and i couldnt really find out why.
So I started over with the install, selected “no domain” at the install and tried to run univention-join from SSH afterwards, to see errors right away. I have replaced my real domain with DOMAIN.REMOVED in all commands and error messages.
After reading a few guides online, I believe that the first UCS in joining an AD must be a master, so my command was:
univention-join -type domaincontroller_master
The error i got was: missing dns service record for _domaincontroller_master._tcp.DOMAIN.REMOVED
Second try after searching online:
univention-join -type domaincontroller_master -dcname sbs2011.DOMAIN.REMOVED
New error: ssh-login to riessadmin@sbs2011.DOMAIN.REMOVED failed with " "
Which is of course correct, as this is a windows server with no ssh running on it.
To me it sounds like the command tries to join a UCS domain, not AD.
Any help would be greatly appreciated.
Best regards in advance,
M
After several tries, i managed to join my first UCS master to an SBS2011. I started from scratch and tried to join the AD during setup. All scripts worked except 26.
  1. there was a problem of a missing DNS of domaincontroller_master. I added that in the SBS2011 DNS.
  2. I re-ran the scripts from the GUI and only 26 didnt work. It told me to use “univention-run-join-scripts --ask-pass”
I tried that and got “Search LDAP binddn: ldap_sasl_bind(SIMPLE): Can’t contact LDAP server (-1)
Insufficient access (50)”
I searched in the forum here and found an info about univention-ssh inside the join script. I debugged /usr/sbin/univention-run-join-scripts and saw, that binddn was not found. I also saw, that “Can’t contact LDAP server (-1)” resulted from the first try, and “Insufficient access (50)” from the second one.
However: univention-ldapsearch uid=ADMIN returned the DN correctly.
So I decided not to debug the univention-ssh problems any more, added binddn=“WHAT_I_GOT_FROM_BEFORE” and with that managed to let the script continue.
And it WORKED!
I don’t feel like signing up for the sourcecode just because of that, but I suggest someone adds another if-statement in /usr/sbin/univention-run-join-scripts to try what i did.
UPDATE:
Trying to add a slave server to the environment, I got stuck during the install process at the same problem and I couldnt continue. So I switched to console and edited /target/usr/sbin/univention-join and manually added binddn=… again.
Would be great if anyone could to help me find a proper solution, i dont feel like manually editing the scripts at every new server I add.
UPDATE 2:
I think I have found the reason behind some of the binddn errors.
I had to add the (Active-Directory-)Domain-Admin-User to the UCS Group “DC Backup Hosts”.
Found this suggestion at another post here regarding some ldap.secret error.
Just wanted to know if the issues, posted in reply 2, were successfully resolved?
Yeah I think so. Have not had any problem like that occur since then.
