Novice here trying to set up a small business network - I have successfully set up a Univention/Zentyal/Windows network but am running into a problem. I have a Univention PDC setup with Zentyal 5 joined to the domain as an “Additional Domain Controller” (SDC - secondary domain controller). Changes in the Univention PDC directory are replicated TO the Zentyal SDC…no problem there…However, changes on the Zentyal SDC are not replicated back TO the PDC?
For instance - When i try to set up the mail server on the SDC changes to the LDAP directory (on the PDC) are being disallowed? I’m getting this info in the /var/log/zentyal/zentyal.log:
INFO> LDAP.pm:246 EBox::Module::LDAP::_sendSchemaUpdate - Sending schema update: CN=fetchmailAccount,CN=Schema,CN=Configuration,DC=XXXXXX,DC=XXX
2017/08/01 08:39:10 ERROR> LDAP.pm:248 EBox::Module::LDAP::_sendSchemaUpdate - Error sending schema update: CN=fetchmailAccount,CN=Schema,CN=Configuration,DC=XXXXXX,DC=XXX The server is unwilling to perform the requested operation
When i joined Zentyal to the domain I’m using a user account that has Domain Admin privilege on the PDC so I’m unsure why replication can’t make it back the PDC?
The samba log (log.samba) on the Univention PDC:
[2017/07/31 16:31:31.706825, 0, pid=1072] …/source4/librpc/rpc/dcerpc_sock.c:63(continue_socket_connect)
Failed to connect host XXX.XXX.XXX.XXX on port 135 - NT_STATUS_CONNECTION_REFUSED
[2017/07/31 16:31:31.706870, 0, pid=1072] …/source4/librpc/rpc/dcerpc_sock.c:246(continue_ip_open_socket)
Failed to connect host XXX.XXX.XXX.XXX (4f620fa4-bdfe-4c40-90ce-f84de2e13ecd._msdcs.test.us) on port 135 - NT_STATUS_CONNECTION_REFUSED.
[2017/07/31 16:31:37.342146, 1, pid=1069] …/lib/ldb-samba/ldb_wrap.c:76(ldb_wrap_debug)
ldb: schema_data_add: updates are not allowed: reject request
[2017/07/31 16:40:48.498367, 1, pid=1069] …/lib/ldb-samba/ldb_wrap.c:76(ldb_wrap_debug)
[2017/07/31 16:44:46.596534, 1, pid=1069] …/lib/ldb-samba/ldb_wrap.c:76(ldb_wrap_debug)
[2017/07/31 16:45:07.182909, 1, pid=1069] …/lib/ldb-samba/ldb_wrap.c:76(ldb_wrap_debug)
[2017/08/01 08:39:06.677361, 1, pid=1069] …/lib/ldb-samba/ldb_wrap.c:76(ldb_wrap_debug)
Any help would be appreciated!
