wir betreiben einen UCS Server…
haben jetzt ein kleines Malheur
Ich hoffe hier Hilfe bekommen zu können
unsere LVM /var Partition war vollgelaufen…
nun haben wir dort wieder Platz geschaffen, jedoch starten einige Dienste nicht mehr…
z.B.
Nagios
SLDAP
Fehlermeldung Nagios:
Checking misc settings…
Error: Unable to write to check_result_path (’/var/lib/nagios3/spool/checkresults’) - No space left on device
Total Warnings: 0
Total Errors: 1
***> One or more problems was encountered while running the pre-flight check…
Check your configuration file(s) to ensure that they contain valid
directives and data defintions. If you are upgrading from a previous
version of Nagios, you should be aware that some variables/definitions
may have been removed or modified in this version. Make sure to read
the HTML documentation regarding the config files, as well as the
'Whats New' section to find out what has changed.
[FAIL] errors in config! … failed!
Fehlermeldung SLDAP:
[FAIL] Starting ldap server(s): slapd …failed.
[info] 56811de8 OVER: Loading Translog Overlay 56811de8 OVER: db_init 56811de8 OVER:
Configuring Translog Overlay 56811de8 OVER: Configured Translog Overlay to use
file “/var/lib/univention-ldap/listener/listener” 56811de8 /etc/ldap/slapd.conf:
line 126: invalid path: No space left on device slapschema: bad configuration file!.
