Univention-dhcp
habe eben einen Univention-slave installiert, dann via UDM in den Basis- Einstellungen das Paket “univention-dhcp” installiert, aber dieser lässt sich nun nicht starten :frowning: …
Im univention-dhcp init skript erfolgt eine Überprüfung:
if [ ! -e /etc/runit/univention/univention-dhcp ]; then exit 0 fi
Dieser Ordner existiert bei mir aber nicht… Auch im Univention-dhcp Paket wird dieser nicht aufgelistet:
root@s-mucs02:/etc/runit/univention-dhcp# dpkg -L univention-dhcp /. /usr /usr/lib /usr/lib/univention-directory-listener /usr/lib/univention-directory-listener/system /usr/lib/univention-directory-listener/system/dhcp.py /usr/lib/univention-install /usr/lib/univention-install/25univention-dhcp.inst /usr/lib/univention-server /usr/lib/univention-server/server_password_change.d /usr/lib/univention-server/server_password_change.d/univention-dhcp /usr/share /usr/share/doc /usr/share/doc/univention-dhcp /usr/share/doc/univention-dhcp/changelog.Debian.gz /usr/share/doc/univention-dhcp/copyright /etc /etc/runit /etc/runit/univention-dhcp /etc/runit/univention-dhcp/down /etc/runit/univention-dhcp/run /etc/runit/univention /etc/dhcp /etc/dhcp/univention.conf /etc/dhcp/local.conf /etc/univention /etc/univention/registry.info /etc/univention/registry.info/variables /etc/univention/registry.info/variables/univention-dhcp.cfg /etc/univention/registry.info/categories /etc/univention/registry.info/categories/univention-dhcp.cfg /etc/univention/templates /etc/univention/templates/info /etc/univention/templates/info/univention-dhcp.info /etc/univention/templates/files /etc/univention/templates/files/etc /etc/univention/templates/files/etc/dhcp /etc/univention/templates/files/etc/dhcp/dhcpd.conf /etc/univention/templates/files/etc/logrotate.d /etc/univention/templates/files/etc/logrotate.d/univention-dhcp /etc/univention/templates/files/etc/init.d /etc/univention/templates/files/etc/init.d/isc-dhcp-server /etc/univention/service.info /etc/univention/service.info/services /etc/univention/service.info/services/univention-dhcp.cfg /etc/univention/daemons /etc/init.d /etc/init.d/univention-dhcp /etc/runit/univention-dhcp/finish
Installiert wurde mit UCS3.0.2 und ist up to date…
Edit: Habe es nun mit “root@s-mucs02:/etc/runit/univention# ln -s …/univention-dhcp/ univention-dhcp” gefixt…
lG
Die Registrierung und Aktivierung erfolgt im Join Skript. Hilft es einmal univention-run-join-scripts auf dem Slave auszuführen?
Aaah danke :slight_smile:
